crash105 Offline
#1 Posted : Tuesday, 22 July 2008 4:35:18 AM(UTC)
crash105
will a 5 speed gearbox from a VK commy fit to a red 202 motor, if so are there any little tricks to fitting.
while asking, does a black 202 head fit on a red block,
i know the inlet and exhaust manifolds will need to be changed
#2 Posted : Tuesday, 22 July 2008 4:50:55 AM(UTC)
crash105 Offline
#3 Posted : Tuesday, 22 July 2008 5:08:16 AM(UTC)
crash105
Cheers Byron
will the black head give me a power increase?
#4 Posted : Tuesday, 22 July 2008 8:26:09 AM(UTC)
The 5 speed will require you to use a blue or black 6 flywheel & clutch.
The blue & black 6 run a larger diameter clutch than the red 6.
The 5 speed driven plate (different splines) is only available in the larger size.
_____________
