will a 5 speed gearbox from a VK commy fit to a red 202 motor, if so are there any little tricks to fitting. while asking, does a black 202 head fit on a red block, i know the inlet and exhaust manifolds will need to be changed
quote: Originally posted by crash105
will a 5 speed gearbox from a VK commy fit to a red 202 motor, if so are there any little |
Cheers Byron will the black head give me a power increase?
The 5 speed will require you to use a blue or black 6 flywheel & clutch. The blue & black 6 run a larger diameter clutch than the red 6. The 5 speed driven plate (different splines) is only available in the larger size.
Mick _____________ |
