ozchevy Offline
#1 Posted : Tuesday, 22 July 2008 4:53:05 AM(UTC)
ozchevy
Im rewiring my Camaro, new fuse box, with 16 circuits and have a single connection from the battery to a battery isolator switch, which then goes to the fusebox, this cable is a 6mm sq conductor, and is able to carry 40 amps, and has thick insulation. so all the fuses come from one bus connection that feeds all the fuses on one side, then off to the lights, horn, heater, wipers etc on the downstream side of the fuse.
Not quite the normal way of wiring a fuse box I know, but this is the way I want to do it, with a specific purpose in mind.
Not sure if this is even looked at, so long as everything works and is fuse protected. Should it be a concern or not.
Thanks guys.
Edited by user Tuesday, 22 July 2008 5:25:30 AM(UTC)  | Reason: Not specified
classic oz wreck Offline
#2 Posted : Tuesday, 22 July 2008 7:17:22 AM(UTC)
classic oz wreck
most inspection stations dont realise that that old holdens have upper control arms with bushes in them so i reckon they wouldnt even look at or know what they were looking at in your case....
going to church makes you no more a christian than standing
www.classicozwreck.com.au
