#1 Posted : Friday, 25 July 2008 5:00:55 AM(UTC)
I am about to register my HT Holden. The car has not been on the road for more than 25 years.
I was making inquires at Vic Roads on how to go about registration and what I needed to bring.
One of the requirements was that the ID Tags matched the Fire wall number or VIN as they called it.
I explained that these numbers did not match until HG 1970.
My Q is what does the body number mean in the ID tag and how can I prove to them the tags have been removed.
Does someone have some reference I can show Vic Roads that my car is they way it should be.
#2 Posted : Friday, 25 July 2008 7:10:40 AM(UTC)
Again a registry authority that has no idea what the hell they are talking about. You are correct that there is no match between the tags until 1/1/70 (but HT). So if it's a 1969 HT there are only two tags and they don't match the body, plus it doesn't ma
#3 Posted : Friday, 25 July 2008 7:10:40 AM(UTC)
Again a registry authority that has no idea what the hell they are talking about. You are correct that there is no match between the tags until 1/1/70 (but HT). So if its a 1969 HT there are only two tags and they dont match the body, plus it doesnt matte
#4 Posted : Friday, 25 July 2008 8:38:24 AM(UTC)
Thanks Byron very much for your comments.
The car is a 69 with only two tags, I think I will have to get some info from Holden them self or one of the Holden clubs.
I am going to make some calls to Vic Roads tomorrow and try and sort it out.
They sai
#5 Posted : Friday, 25 July 2008 5:55:59 PM(UTC)
This is not new, and Byron it is not that they do not know what is going on it is that the value of these cars is so high they want to make sure that this car is NOT the stolen Moanro from winter sun.
Lets face some facts here, most Moanro owners do no
#6 Posted : Friday, 25 July 2008 6:14:15 PM(UTC)
I don't know Warren, in my area they seem to be sometimes be on the side of "not knowing what they are talking about" with older cars. How else would a Holden V8 end up with an engine number recorded as 12784563! (This was pre blue slips of course).
__
#7 Posted : Friday, 25 July 2008 6:14:15 PM(UTC)
I dont know Warren, in my area they seem to be sometimes be on the side of "not knowing what they are talking about" with older cars. How else would a Holden V8 end up with an engine number recorded as 12784563! (This was pre blue slips of course).
___
tanart Offline
#8 Posted : Friday, 25 July 2008 9:05:05 PM(UTC)
tanart
I too am in the process of registering my HT GTS built july 69. The ID plates have never been remove. Please let me know how you go as i'm about a month away.
tanart Offline
#9 Posted : Friday, 25 July 2008 9:05:05 PM(UTC)
tanart
I too am in the process of registering my HT GTS built july 69. The ID plates have never been remove. Please let me know how you go as im about a month away.
tanart Offline
#10 Posted : Friday, 25 July 2008 9:08:19 PM(UTC)
tanart
Also, ,my car didn't come out with rear seat belts (optional). How do i explain this when getting a roadworthy? I'll end up putting rear seat belts when i find a good set of black ones.
tanart Offline
#11 Posted : Friday, 25 July 2008 9:08:19 PM(UTC)
tanart
Also, ,my car didnt come out with rear seat belts (optional). How do i explain this when getting a roadworthy? Ill end up putting rear seat belts when i find a good set of black ones.
#12 Posted : Friday, 25 July 2008 11:37:50 PM(UTC)
I always had my 57 Chev on Club rego and always wondered how Id go registering it with no seatbelts. The offical line is it doesnt have to have them, but official stuff sometimes doesnt make its way down to those issuing blue slips. At one stage I was goi
#13 Posted : Friday, 25 July 2008 11:37:50 PM(UTC)
I always had my '57 Chev on Club rego and always wondered how I'd go registering it with no seatbelts. The offical line is it doesn't have to have them, but official stuff sometimes doesn't make it's way down to those issuing blue slips. At one stage I wa
Robbo Offline
#14 Posted : Saturday, 26 July 2008 12:31:49 AM(UTC)
Robbo
The rego office here [qld] is over the top as well.I bought a vy ss sedan from the local holden dealer,and when I went to change the plates over the rego paper had a seating capacity of four.I was then informed the vehicle had to go over the pits for an
There Is No Replacement For Displacement.
#15 Posted : Saturday, 26 July 2008 1:05:09 AM(UTC)
Hi Guys.
In NSW, if the car was built before 1-Jan-65 and it is not modified, it won't need any seat belts.
Also in NSW, it won't need rear belts unless the ADR plate says it needs them.
Dr Terry.
Edited by user Saturday, 26 July 2008 1:11:09 AM(UTC)  | Reason: Not specified
#16 Posted : Saturday, 26 July 2008 1:05:09 AM(UTC)
Hi Guys.
In NSW, if the car was built before 1-Jan-65 and it is not modified, it wont need any seat belts.
Also in NSW, it wont need rear belts unless the ADR plate says it needs them.
Dr Terry.
#17 Posted : Saturday, 9 August 2008 3:06:39 AM(UTC)
Well the saga continues.
After about 50 phone calls all over the country including Holden themselves (no clue). I am starting to make progress.
After discussions with Dr Terry and Byron then again with Vic roads.
I have found out what I need.
Vic r
#18 Posted : Saturday, 9 August 2008 3:18:25 AM(UTC)
warren_turnbullAThotmailDOTcom
You know the deal with the AT and DOT.
Warren
gts-garry Offline
#19 Posted : Saturday, 9 August 2008 7:17:21 AM(UTC)
gts-garry
When i got my HT gts rego and roadworthy done in vic last year, the r/w guy said if it had the mounting holes for the seat belts they had to be fitted.When at the rego ofice they said that because my monaro was not fitted with a compliance plate eg pre 19
nhawtin Offline
#20 Posted : Saturday, 9 August 2008 5:26:23 PM(UTC)
nhawtin
Mate I had a car that the tags where removed and lost off a HK monaro during a 20 year rebuild. Since then I have found the tags etc off the car but during this time i researched a little with Vic Roads and came up with some documentation that may be of i
Guest (11)
