#1 Posted : Saturday, 26 July 2008 2:51:10 AM(UTC)
Here is a good project for someone. Id buy it myself but too far to drive:
http://cgi.ebay.com.au/C...WDVWQQrdZ1QQcmdZViewItem
#2 Posted : Saturday, 26 July 2008 5:16:09 AM(UTC)
my son in law has one of those in his shed from a mercruiser setup, the leg was stuffed, I thought about putting it in my bedford truck to replace the 173, Les hassles than V8,
what would be good gearbox to go with it?
#3 Posted : Saturday, 26 July 2008 5:55:59 AM(UTC)
TH400 or TH350 or TH700R4. It will bolt straight up to the 3 speed if that is what is in the Bedford with a bellhousing to suit 308 turbo to aussie 4 speed. You'd just have to put a V8 input shaft into the 3 speed. I'd use a Chev 11" flywheel as well.
#4 Posted : Saturday, 26 July 2008 5:55:59 AM(UTC)
TH400 or TH350 or TH700R4. It will bolt straight up to the 3 speed if that is what is in the Bedford with a bellhousing to suit 308 turbo to aussie 4 speed. Youd just have to put a V8 input shaft into the 3 speed. Id use a Chev 11" flywheel as well.
__
#5 Posted : Wednesday, 6 August 2008 1:10:53 AM(UTC)
Hi, im considering throwing a 292 into a uc torana i have but just cant manage to find any info on what engine mounts to use and other things along those lines. only thinkin of doin it cos i have a few in old trucks out the back.
boom Offline
#6 Posted : Wednesday, 6 August 2008 4:40:53 AM(UTC)
boom
HK1837 said they use SBC engine mounts, so just like fitting a SBC to an LH or LX.
In cubes we trust.
#7 Posted : Wednesday, 6 August 2008 5:06:13 AM(UTC)
What I meant was they bolt in wherever a SBC bolts in, just like a Holden 6 shares the same chassis mounts as a 253/308. Not sure if they can use SBC into HQ adapters and mounts on the engine. It shouldn't be hard to make it fit though.
_______________
#8 Posted : Wednesday, 6 August 2008 5:06:13 AM(UTC)
What I meant was they bolt in wherever a SBC bolts in, just like a Holden 6 shares the same chassis mounts as a 253/308. Not sure if they can use SBC into HQ adapters and mounts on the engine. It shouldnt be hard to make it fit though.
________________
musksell Offline
#9 Posted : Wednesday, 6 August 2008 6:08:33 AM(UTC)
musksell
292....use different engine mounts to sbc
#10 Posted : Wednesday, 6 August 2008 6:40:40 PM(UTC)
Hi Guys.
What HK1837 is trying to say is that the 292 6-cyl Chev will fit in the same spot as an SBC.
Yes, the mounts themselves are different, but where they mount is in the same position using the same bolt.
In any Holden you can simply use the
boom Offline
#11 Posted : Thursday, 7 August 2008 5:46:44 AM(UTC)
boom
ah, ok i get what you mean.
In cubes we trust.
musksell Offline
#12 Posted : Thursday, 7 August 2008 6:00:45 AM(UTC)
musksell
I rang Hadfield some time ago about this, he does not make the mounts, and yes they are different. They might well fit onto the same mounts as any chev, which is usually the old way Yanks did it, but according to Hadfield its very different for HQ-WBs
musksell Offline
#13 Posted : Thursday, 7 August 2008 6:00:45 AM(UTC)
musksell
I rang Hadfield some time ago about this, he does not make the mounts, and yes they are different. They might well fit onto the same mounts as any chev, which is usually the old way Yanks did it, but according to Hadfield its very different for HQ-WB'
#14 Posted : Thursday, 7 August 2008 6:47:34 AM(UTC)
I looked at this a while ago, but using the C20/K20 style mounts it isn't quite as easy as using HK-HG mounts adapters. I haven't actually tried it, but just measured (for my HZ Overlander). The 292 block has a similar setup on the side as a Holden 6 with
#15 Posted : Thursday, 7 August 2008 6:47:34 AM(UTC)
I looked at this a while ago, but using the C20/K20 style mounts it isnt quite as easy as using HK-HG mounts adapters. I havent actually tried it, but just measured (for my HZ Overlander). The 292 block has a similar setup on the side as a Holden 6 with t
#16 Posted : Thursday, 7 August 2008 7:17:21 PM(UTC)
How does the 292 compare length,width and most importantly weight with a holden inline 6.
I thought I read somewhere its weight is similar or indeed heavier than a small block?
Can someone run a tape over one (if its handy)
#17 Posted : Thursday, 7 August 2008 8:02:46 PM(UTC)
#18 Posted : Thursday, 7 August 2008 8:18:28 PM(UTC)
i suspected as much, thanks for the quick reply Doc.
Phill
#19 Posted : Thursday, 7 August 2008 11:14:03 PM(UTC)
Definitely bigger and heavier. Perfect for 4WD conversions. Will eat a 308 for breakfast torque wise and can run an 11" flywheel which is very important in torque production. They can also be made to go very hard with an increase in compression, good cam,
musksell Offline
#20 Posted : Saturday, 9 August 2008 5:08:48 AM(UTC)
musksell
Are you going to put the pictures up Byron....?
This page was generated in 0.102 seconds.
