trev10 Offline
#1 Posted : Saturday, 26 July 2008 8:24:13 PM(UTC)
trev10
Guys,
Can someone shed some light on the use of hub centering rings as I have a set of Cragar SS rims that are multi fit. I have noticed that with the car on stands and in gear, the rims are almost impossible to center. Should I be looking at getting some centering rings for these rims and if so, can someone suggest an online store that will be able to supply them. Am I looking in the right area as I havent had much to do with these centering rings before.
Cheers in advance Trev...
trev10 Offline
#2 Posted : Saturday, 26 July 2008 8:52:34 PM(UTC)
trev10
Just to add,
I have noticed there is heaps of them on ebay. Would anyone know the hub diameter of the axles on a 10 bolt salisbury (drum) and the front hub diameter as this will make up the ID requirements for the spacers. I will have to measure th
mmazz30 Offline
#3 Posted : Sunday, 27 July 2008 2:32:09 AM(UTC)
mmazz30
From what i can measure with the studs in the way...70.50 - 71.45mm front or rear.
cheers...mario
tanart Offline
#4 Posted : Sunday, 27 July 2008 3:37:56 AM(UTC)
tanart
Trev, i have a set on my HK GTS although i have HQ front stud pattern and ford rear stud pattern (9inch). However these dont fit my HT GTS which has the original 10bolt and front hubs.
#5 Posted : Sunday, 27 July 2008 6:09:02 AM(UTC)
isn't the multi fits ones illegal in Australia we bought a set
of 17 x 7 ones recently that have the round hole like all the other rims.
http://i109.photobucket....Toyota%20Crown/612-1.gif
#6 Posted : Sunday, 27 July 2008 6:09:02 AM(UTC)
isnt the multi fits ones illegal in Australia we bought a set
trev10 Offline
#7 Posted : Sunday, 27 July 2008 5:48:22 PM(UTC)
trev10
I measured the rims and the rear axle and came up with ID rim ~91.00mm, OD Axle ~ 71.00mm so looks like the centering rings will be around the 20mm mark. Now all I have to do is find someone who has a set or get some made. Anyone able to help.
Thanks Tre
