#1 Posted : Sunday, 27 July 2008 9:49:05 PM(UTC)
Hey Guys,
My carbie is knackered... was using a 4 Barrel Q-Jet and all the vaccum advances are shot, theres free play and my mate tells me that its sucking air big time... Its been running rich and my spark plugs are now darker than a coalminers asshole :)
Anyway, I'm not mechanically minded and don't really know where i should go. My mate, who is a mechanic, is trying to sell me his Holley Carbie, 600 i think, with mechanical secondaries. I think he's trying to sell it to me, not really caring if it suits or not and just wants 400 hundred for it!
Anyway, i've read that its common that people drop to powerful of a carbie on engines that aren't suited. Mine is just a straight 253, Trimatic, in a Panel van. Nothing worked and is run of the mill... and i want to keep it that way, just after a sunday driver - not a drag racer?
If you guys could reply and let me know of any carbies recommended that would be great.... My Pano has no choke in the dash and my mate is saying i dont need a choke, other people say go electic choke....
Any advice????
meecar Offline
#2 Posted : Sunday, 27 July 2008 10:39:47 PM(UTC)
meecar
go and give it a tune failing that goto the wreckers and buy the same carby youve got now or a 2 barrel
meecar Offline
#3 Posted : Sunday, 27 July 2008 10:39:47 PM(UTC)
meecar
go and give it a tune failing that goto the wreckers and buy the same carby you've got now or a 2 barrel
#4 Posted : Sunday, 27 July 2008 11:36:08 PM(UTC)
Hey,
Nothing wrong with a 600 Holley, as long as it's a vacuum secondary model for your engine. The only downfall is it may just a fraction too big for a 253 if it's just a stock run around. If you can find a Holley 465 in good condition, that would be
#5 Posted : Sunday, 27 July 2008 11:36:08 PM(UTC)
Hey,
Nothing wrong with a 600 Holley, as long as its a vacuum secondary model for your engine. The only downfall is it may just a fraction too big for a 253 if its just a stock run around. If you can find a Holley 465 in good condition, that would be a
#6 Posted : Sunday, 27 July 2008 11:53:54 PM(UTC)
hey carby dude... thanks for your advice... The 600 holley, doesnt have vac secondaries. They are mechanical... he said something like a 620 but i can't confirm? I wouldnt mind just a good working Quadie... I'm concerned about choke though - he tells me t
#7 Posted : Sunday, 27 July 2008 11:53:54 PM(UTC)
hey carby dude... thanks for your advice... The 600 holley, doesnt have vac secondaries. They are mechanical... he said something like a 620 but i cant confirm? I wouldnt mind just a good working Quadie... Im concerned about choke though - he tells me tha
mmazz30 Offline
#8 Posted : Monday, 28 July 2008 1:08:50 AM(UTC)
mmazz30
The vacuum break is there to control the secondary air flap opening when flooring the car.
If the car is "sucking air bigtime"...it would most likely be causing it to lean out...not run rich.
Quaddies have problems with the floats absorbing fuel and not
#9 Posted : Monday, 28 July 2008 1:22:21 AM(UTC)
So what do you suggest mario???
mmazz30 Offline
#10 Posted : Monday, 28 July 2008 3:51:09 AM(UTC)
mmazz30
Fix the quaddie!
#11 Posted : Monday, 28 July 2008 5:55:11 PM(UTC)
Give me a call if you want one of those quadies on 0428837490
I'm in SA
#12 Posted : Monday, 28 July 2008 5:55:11 PM(UTC)
Im in SA
HQforme Offline
#13 Posted : Thursday, 31 July 2008 8:34:03 AM(UTC)
HQforme
Pretty sure a 600 is too big on a mild 253, especially with mechanical secondaries. Sure, it's not the last word in too big, but go for something smaller. Or have yours reconditioned.
"Silly modern cars"
HQforme Offline
#14 Posted : Thursday, 31 July 2008 8:34:03 AM(UTC)
HQforme
Pretty sure a 600 is too big on a mild 253, especially with mechanical secondaries. Sure, its not the last word in too big, but go for something smaller. Or have yours reconditioned.
"Silly modern cars"
Oily Offline
#15 Posted : Thursday, 31 July 2008 10:02:59 AM(UTC)
Oily
Hi Carby
Quadrajet should work fine and are ideal if set up properly, As they have small primary venturies for running at light load(economy)and larger secondaries for heavy load/high speed (power).
Most of their faults have been mentioned. but sometime
#16 Posted : Friday, 1 August 2008 1:06:12 AM(UTC)
Thanks Guys...
As an update - got a Reconditioned Quadrajet from Melb Cars and Injectors... Geoff there, was an absolute legend. I'm no mechanic so he helped me out, showed me what i needed, gave me a gasket and spacer, cable for electric choke etc and
#17 Posted : Friday, 1 August 2008 1:06:12 AM(UTC)
Thanks Guys...
As an update - got a Reconditioned Quadrajet from Melb Cars and Injectors... Geoff there, was an absolute legend. Im no mechanic so he helped me out, showed me what i needed, gave me a gasket and spacer, cable for electric choke etc and
mmazz30 Offline
#18 Posted : Friday, 1 August 2008 7:33:34 AM(UTC)
mmazz30
Good to hear it all went well for you.
cheers...Mario
Guest (11)
This page was generated in 0.195 seconds.
