vanman Offline
#1 Posted : Monday, 28 July 2008 11:38:42 PM(UTC)
vanman
Hi is there anyone with experience in Filling in side windows on a panel van?
I have a HJ sandman with a couple of windows in the rear
I have another windowless hj that i can part out as its rusty down low..
Is picking the panels and replacing the sides a better option..?
Carl
Edited by user Monday, 28 July 2008 11:43:37 PM(UTC)  | Reason: Not specified
#2 Posted : Monday, 28 July 2008 11:41:58 PM(UTC)
glue them in with a product that Wurth make, similar to the stuff the factory make when glueing in firewalls from VN onwards. Unpicking is a major job, believe me, we have done both
"ALL WE LEAVE IS MEMORIES.."
"ANYONE CAN RESTORE A CAR, BUT IT TAK
#3 Posted : Tuesday, 29 July 2008 12:16:13 AM(UTC)
You'll have to replace the internal struts too, so unpick them off the other van. I'd just get a good beater to cut replacement sections out of the other van and weld them in using a TIG. It's only yellow, not like it's black or a dark colour.
________
#4 Posted : Tuesday, 29 July 2008 12:16:13 AM(UTC)
Youll have to replace the internal struts too, so unpick them off the other van. Id just get a good beater to cut replacement sections out of the other van and weld them in using a TIG. Its only yellow, not like its black or a dark colour.
____________
#5 Posted : Tuesday, 29 July 2008 5:42:41 AM(UTC)
make sure the side panels are straight to begin with. some windowed vans i have seen when you look down the sides dont match up. its almost impossible to straighten. as them braces are gone and the panels have flexed too much. when its finished it looks r
vintageholden Offline
#6 Posted : Tuesday, 29 July 2008 6:46:09 AM(UTC)
vintageholden
where are you
i have done heaps of them
vanman Offline
#7 Posted : Tuesday, 29 July 2008 10:04:45 AM(UTC)
vanman
I'm in victoria near Shepparton... its only a short window i think all the braces are there...
vanman Offline
#8 Posted : Tuesday, 29 July 2008 10:04:45 AM(UTC)
vanman
Im in victoria near Shepparton... its only a short window i think all the braces are there...
vanman Offline
#9 Posted : Tuesday, 29 July 2008 5:59:26 PM(UTC)
vanman
where are you i have done heaps of them
Whats the b
#10 Posted : Tuesday, 29 July 2008 6:50:20 PM(UTC)
One brace each side will probably be gone by the photo you posted. Pull the windows out and get a panel beater to have a look and tell you what they think. You can also buff the paint up and look down it and see how straight it is, and also run a straight
vanman Offline
#11 Posted : Wednesday, 30 July 2008 3:52:06 AM(UTC)
vanman
Yea you are right one brace is gone...I think it may be Better to repair the rusty shell..its not that bad just rusty beaver and lower rear quaters..gutters and sills are solid..
vanman Offline
#12 Posted : Wednesday, 30 July 2008 3:52:06 AM(UTC)
vanman
Yea you are right one brace is gone...I think it may be Better to repair the rusty shell..it's not that bad just rusty beaver and lower rear quaters..gutters and sills are solid..
#13 Posted : Wednesday, 30 July 2008 4:15:08 AM(UTC)
I'd be careful of that too as there are differences between HJ-HZ shells and some have a stamped firewall number that "belongs" to the tags - if you know your Holdens you can pick a rebody. Putting the braces back is easy. You just need a quality panel be
#14 Posted : Wednesday, 30 July 2008 4:15:08 AM(UTC)
Id be careful of that too as there are differences between HJ-HZ shells and some have a stamped firewall number that "belongs" to the tags - if you know your Holdens you can pick a rebody. Putting the braces back is easy. You just need a quality panel bea
#15 Posted : Wednesday, 30 July 2008 7:51:16 AM(UTC)
I know it's not entirely impossible to change a van into a ute but how hard would it be to swap the whole roof upwards of where it joins the top of the quarter panels?
Drill a few hundred spot welds or much more involved?
#16 Posted : Wednesday, 30 July 2008 7:51:16 AM(UTC)
I know its not entirely impossible to change a van into a ute but how hard would it be to swap the whole roof upwards of where it joins the top of the quarter panels?
#17 Posted : Wednesday, 30 July 2008 9:07:33 AM(UTC)
vintageholden
if you havent welded much i wouldnt risk it
cut a piece the same size and take weld all the corners dont do and long runs it will warp....if you can heat shrink as well that will help get the distorsions out
work opposite the weld you just did to stop t
t-dog Offline
#18 Posted : Wednesday, 30 July 2008 9:52:59 AM(UTC)
t-dog
hi byron
what are the differences between hj and hz pvan bodyshells as i have one of each and cant tell
ooowwww yeh! thats what im talkin bout!
#19 Posted : Wednesday, 30 July 2008 6:04:45 PM(UTC)
Wiring harness plug on firewall, mounting stud for HQ style rat-trap, high beam dipper switch. Plus mid HZ onwards had a double pivot point for clutch pedal (like WB - 6cyl pedal goes in top hole, V8 pedal goes in bottom hole). And of course the firewall/
vanman Offline
#20 Posted : Wednesday, 30 July 2008 7:19:18 PM(UTC)
vanman
Both my bodys are HJ and neither has the number in the top center of the firewall so would a body swap be detectable ?
This page was generated in 0.083 seconds.
