Ado Offline
#1 Posted : Wednesday, 30 July 2008 11:26:24 PM(UTC)
Ado
Have a 6cyl hz sedan with three on the tree. It has a 3.55 bajo fine spline diff. What is a good set up that will help with fuel costs with only using holden parts. Maybe a diff change,would like to keep the 3sp man. maybe even a smaller red motor. Would rather holden bits to keep cost down. The car weighs 1350kg.Any advice would be great.Thanks.
peterwmh Offline
#2 Posted : Thursday, 31 July 2008 12:15:58 AM(UTC)
peterwmh
I had the same setup as you and was getting 14 litres/100kms out of it, I changed to a 3.08:1 diff centre and changed to electronic ignition and lost a bit of pickup on takeoff, but if prepared for that the old girl got around 12-13litres/100kms so a good
Ado Offline
#3 Posted : Thursday, 31 July 2008 1:17:29 AM(UTC)
Ado
Thankyou peterwmh.these things are within reach for this bush mechanic. Realize cant expect mi8racles with economy but 12-13 liters per 100km is better than what i get at the moment.
Where could you source a cheap 3.08 banjo,have a spare 3.36 but defin
JBM Offline
#4 Posted : Thursday, 31 July 2008 1:31:21 AM(UTC)
JBM
Another thing to consider is LPG conversion costs less the rebate compared to fuel cost savings. The rebate is more than half the conversion cost.
Combined with the diff change youll get your money back quicker.
You may only need to swap to the 3.36
Edited by user Thursday, 31 July 2008 1:32:17 AM(UTC)  | Reason: Not specified
#5 Posted : Thursday, 31 July 2008 1:48:33 AM(UTC)
Another twist - change to a 2.78:1 diff and replace the 3 speed with an M22 aussie 4spd. An M22 will bolt in exactly where the 3 speed is and use the 3 speed bellhousing and clutch setup. You just have to cut the hole in the floor for the shifter and run
Ado Offline
#6 Posted : Thursday, 31 July 2008 2:47:57 AM(UTC)
Ado
Never fully thought of LPG. The state government in WA also give some money back i believe. Yeah i thought 3.08banjos were thin on the ground and snatched up by guys with rare cars like xu1,s and the like.
Its funny Byron Rich, i have a vb wagon with the
#7 Posted : Thursday, 31 July 2008 4:41:08 AM(UTC)
Yes banjo 2.78s are around and pretty common, but still difficult. All blue motors had HEI.
#8 Posted : Thursday, 31 July 2008 4:41:08 AM(UTC)
Yes banjo 2.78's are around and pretty common, but still difficult. All blue motors had HEI.
vintageholden Offline
#9 Posted : Thursday, 31 July 2008 5:28:44 AM(UTC)
vintageholden
i have a 3.3 blue auto in my hz on gas. and get 290kms out of $20
better than i was gettting on fuel
thats about 10L per 100kms almost....
Edited by user Thursday, 31 July 2008 5:31:07 AM(UTC)  | Reason: Not specified
#10 Posted : Thursday, 31 July 2008 6:16:39 AM(UTC)
Was thinking about your diff. Forget the banjo - too expensive and hard to find. Just find a HQ-HZ 2.78 or 2.60:1 Salisbury out of any V8 Statesman, sedan or wagon. These are cheap as chips ($100 or so). You'll also need a V8 sedan or Monaro tailshaft tha
#11 Posted : Thursday, 31 July 2008 6:16:39 AM(UTC)
Was thinking about your diff. Forget the banjo - too expensive and hard to find. Just find a HQ-HZ 2.78 or 2.60:1 Salisbury out of any V8 Statesman, sedan or wagon. These are cheap as chips ($100 or so). Youll also need a V8 sedan or Monaro tailshaft that
musksell Offline
#12 Posted : Thursday, 31 July 2008 6:22:02 AM(UTC)
musksell
put the 3.36 in....that be about 2800rpm at 100km, then when tyres wear out put some bigger rubber on, and lower revs another 100.
I wouldnt think you would want to go below 2500rpm at 100km per hour, unless you live in a real flat part of town....
musksell Offline
#13 Posted : Thursday, 31 July 2008 6:22:02 AM(UTC)
musksell
I wouldn't think you would want to go below 2500rpm at 100km per hour, unless you live in a real flat part of town....
HQforme Offline
#14 Posted : Thursday, 31 July 2008 8:23:59 AM(UTC)
HQforme
Some good ideas here guys.... couple of questions relating to my HQ. Would the 4 speed floor shift bolt in directly for the 3speed box in my Kingswood as well? I'd assume so? Although both top gear's are 1to1 (correct?) i'd appreciate the ability to shift
"Silly modern cars"
HQforme Offline
#15 Posted : Thursday, 31 July 2008 8:23:59 AM(UTC)
HQforme
Some good ideas here guys.... couple of questions relating to my HQ. Would the 4 speed floor shift bolt in directly for the 3speed box in my Kingswood as well? Id assume so? Although both top gears are 1to1 (correct?) id appreciate the ability to shift pr
"Silly modern cars"
#16 Posted : Thursday, 31 July 2008 11:02:56 AM(UTC)
You must have a low diff my one tonner would run at just on 3000 rpm at 100kph,give or take 100 depending on road service, and that was a trimatic. tonners generally have something like like a 4.55 diff or 4.11.
#17 Posted : Thursday, 31 July 2008 5:52:31 PM(UTC)
4.44
#18 Posted : Thursday, 31 July 2008 5:55:16 PM(UTC)
#19 Posted : Thursday, 31 July 2008 10:29:16 PM(UTC)
I know that you want to keep it all Holden to keep the costs down but a steel case Celica 5 speed is a cheap and effective conversion if you have the front layshaft bearings upgraded in the box it should live forever behind a 202.
musksell Offline
#20 Posted : Friday, 1 August 2008 5:49:46 AM(UTC)
musksell
4.44 is about 3700rpm at 100km, 3.55 is 300 at 100km per hour std 14 inch appox.
