coopers308 Offline
#1 Posted : Tuesday, 5 August 2008 6:47:29 AM(UTC)
coopers308
Does anyone out there know the casting numbers for holden 6 heads. Or does anyone know a definate way to identify red heads? Apart from the obvious - 202 @ 186 are open cahamber, 186 has adjustable rockers, 179 is obvious as it is the only one with closed chamber and non adjustable rockers, what about the rest? I believe all the rest are closed chamber adjustable rocker type? Surely by looking at the heads or numbers you can identify a 149 from a 161 for example. Any help is much appreciated.
#2 Posted : Tuesday, 5 August 2008 7:39:12 AM(UTC)
There are only a few types althoughthere are probably a few more casting numbers than types and there is also the pollution red heads (from memory so correct mistakes please):
202, low comp 173 and I think low comp 138 - open chamber and rocker bridges
#3 Posted : Tuesday, 5 August 2008 8:08:12 AM(UTC)
Close chamber are 138 149 161 173. and XU-1 202 186?
open chamber are 202 186 179.
low comp 173 161 149 i think are open chamber.
all 6 cyl red motors are adjustable up to HG & LC.
HQ & LJ 202 173 on, all got non adj rockers.
coopers308 Offline
#4 Posted : Tuesday, 5 August 2008 8:13:48 AM(UTC)
coopers308
Thanks HK1837, is it not right that 179 has closed chamber and non adjustable rockers? I thought the high and low comp was alot to do with what pistons where used (flat tops, dish top etc), does it apply to the head as well?
#5 Posted : Tuesday, 5 August 2008 8:23:43 AM(UTC)
no the 179 is same as 186 etc head. you are thinking of the 173. the 179 etc with non-adjustables went up to 71 (before release of HQ) and then all the heads were non adjustable. Also there was no cc 186 or 179 heads
#6 Posted : Tuesday, 5 August 2008 8:23:43 AM(UTC)
At the back of the cyl head, on the left above the number 6 exhaust port, there is usually a H or a L. H stands for closed. L for open.
Some times there is a number, i have seen the number 4. and a 9 in its place?
#7 Posted : Tuesday, 5 August 2008 8:23:43 AM(UTC)
At the back of the cyl head, on the left above the number 6 exhaust port, there is usually a 'H' or a 'L'. H stands for closed. L for open.
Some times there is a number, i have seen the number 4. and a 9 in it's place?
#8 Posted : Tuesday, 5 August 2008 8:24:48 AM(UTC)
sorry that should read
the 179 etc with *adjustables*
#9 Posted : Tuesday, 5 August 2008 8:26:32 AM(UTC)
im not sure that is right rosenberg as the H and L doesnt always seem to add up to that. i could be wrong but i thought i saw it discussed here
#10 Posted : Tuesday, 5 August 2008 8:34:45 AM(UTC)
H is high, L is low but it only applies where the compression ratio is determined by the head and not to XU-1. 179, 186 and 202 use dished pistons for low comp engine and I think 138 does too.
If
coopers308 Offline
#11 Posted : Tuesday, 5 August 2008 8:39:35 AM(UTC)
coopers308
Thanks guys for your input, i really thought it would be as simple as casting numbers would let you know what head it is without taking it off to look at the chambers ie 2811930 is a 202. I cant seem to find a list anywhere of holden 6 cyl head casting n
#12 Posted : Tuesday, 5 August 2008 8:59:15 AM(UTC)
Post the numbers you have and ill see what I can find. The H and L are the best pointers.
#13 Posted : Tuesday, 5 August 2008 8:59:15 AM(UTC)
Post the numbers you have and i'll see what I can find. The H and L are the best pointers.
#14 Posted : Tuesday, 5 August 2008 7:56:43 PM(UTC)
Hi Guys.
The best method of ID is the casting number. On all Red 6-cyl heads this can be seen without removing the rocker cover, which is necessary on Holden V8 & Blue 6-cyl engines.
Its a bit complicated because some engines were built with either
#15 Posted : Tuesday, 5 August 2008 7:56:43 PM(UTC)
Hi Guys.
It's a bit complicated because some engines were built with either
#16 Posted : Wednesday, 6 August 2008 3:02:53 AM(UTC)
NO low comp 186? prefix
HR 186A
HR 186K
HK-T-G 186P
HK-T-G 186S
LOW COMP 186?
#17 Posted : Wednesday, 6 August 2008 3:21:44 AM(UTC)
the 186S engines had the same CR as their low-po counterparts. Lots of other things were changed but the compression remained the same
coopers308 Offline
#18 Posted : Wednesday, 6 August 2008 4:53:46 AM(UTC)
coopers308
Thanks Dr Terry for the info, does a list of these casting numbers exist? Im a bit of a collector of casting numbers and cannot find any info on them at all!
bazza30555 Offline
#19 Posted : Wednesday, 6 August 2008 5:13:23 AM(UTC)
bazza30555
Hi, I think the 138 piston had half the top raised higher than the other side. L C 138 had adjustable rockers from memory. Bazza
adam PERTH Offline
#20 Posted : Wednesday, 6 August 2008 7:06:06 AM(UTC)
adam PERTH
is it possible to contribute and make a master list of casting numbers for holden 6 heads?
this could be a reference point from now on?
stuff like,
casting number for LC GTR / + XU-1 included etc.?
does anyone have this info?
"bog and Flog"
This page was generated in 0.111 seconds.
