#1 Posted : Tuesday, 5 August 2008 7:58:19 AM(UTC)
Has anyone bought a reconditioned hq - wb steering box.if so do you know if they install new gears etc and if you have bought one are they nice and tight when you bought them ( Like a new one )
#2 Posted : Tuesday, 5 August 2008 11:53:45 PM(UTC)
Hi fitzsi.
It depends what people define as 'reconditioned'.
Many workshops just dismantle, clean & reassemble the box with a new seal kit & called it reconditioned.
With the HQ-WB type, they require a bit more than that. The pinion valve alway
#3 Posted : Tuesday, 5 August 2008 11:53:45 PM(UTC)
Hi fitzsi.
It depends what people define as reconditioned.
With the HQ-WB type, they require a bit more than that. The pinion valve always
#4 Posted : Wednesday, 6 August 2008 12:34:31 AM(UTC)
Thanks for taking the time to answer my question.I have one in my 32 Ford Hotrod ( It's OK it has all chev and Holden running gear )and it does have a little steering play.So you would say that a rare spares reconditioned unit would eliminate most play th
#5 Posted : Wednesday, 6 August 2008 12:34:31 AM(UTC)
Thanks for taking the time to answer my question.I have one in my 32 Ford Hotrod ( Its OK it has all chev and Holden running gear )and it does have a little steering play.So you would say that a rare spares reconditioned unit would eliminate most play the
Rhys Offline
#6 Posted : Wednesday, 6 August 2008 1:53:38 AM(UTC)
Rhys
I have bought 2 reconditioned/exchange HQ-WB power steering boxes from Australian Power Steering (via Coventrys in WA) for two different vehicles. The first one I bought was tight with no play at all, but the second one had play in the straight ahead posi
#7 Posted : Wednesday, 6 August 2008 2:55:28 AM(UTC)
Hi Rhys.
I got several e-mails from this site, thru my profile last week, but none about master cylinders.
Best phone me at work (02) 9644-2888. I can also fill you in about steering boxes.
HQwagon202 Offline
#8 Posted : Friday, 8 August 2008 3:22:52 AM(UTC)
HQwagon202
is there a manual steering box that is easy or perhaps easier than the one i have in my HQ Kingy?
My car originally made in 1974 and matched to a 202 engine, i now have 7 inch rims at the front and steering at slow speed is heavy, no problem at the hi
vintageholden Offline
#9 Posted : Friday, 8 August 2008 6:11:33 AM(UTC)
vintageholden
how much do you recond them for???
hz
peterwmh Offline
#10 Posted : Saturday, 9 August 2008 12:14:19 AM(UTC)
peterwmh
John, the HX and later manual steering boxes are a better ratio for easier steering at lower speeds, but you need to twirl them a bit more when doing U turn!! They arent like a powersteer box but they are better!
202 and three on the tree, cant get mo
peterwmh Offline
#11 Posted : Saturday, 9 August 2008 12:14:19 AM(UTC)
peterwmh
John, the HX and later manual steering boxes are a better ratio for easier steering at lower speeds, but you need to twirl them a bit more when doing U turn!! They aren't like a powersteer box but they are better!
HQwagon202 Offline
#12 Posted : Saturday, 9 August 2008 12:50:29 AM(UTC)
HQwagon202
thanks for that info peter
regards John
#13 Posted : Saturday, 9 August 2008 12:55:03 AM(UTC)
