adam PERTH Offline
#1 Posted : Wednesday, 6 August 2008 6:59:28 AM(UTC)
adam PERTH
hey guys, does anyoe know the dimensions to cut into the bonnet for a shaker on an XY?.
save me alot of time as its in the panel shop at the moment.
thanks in advance.
"bog and Flog"
#2 Posted : Wednesday, 6 August 2008 7:19:53 AM(UTC)
here you go:
http://www.fordforums.co...t=46111&highlight=shaker
If at first you don't succeed then skydiving is not for you.
ZC-Cruiser Offline
#3 Posted : Wednesday, 6 August 2008 7:20:15 AM(UTC)
ZC-Cruiser
The shaker hole starts 6 inches from the rear of the bonnet.
You can get a template for cutting the hole.
Are you doing GT Bonnet stripes?
It's good to honk in a Henry
Sutts Offline
#4 Posted : Sunday, 10 August 2008 11:05:04 PM(UTC)
Sutts
Hey there.
You should buy the the Shaker bonnet hood template for cutting out the hole from www.fomoco.com.au
Part number SHAKBHT-02 only cost's $35 so a lot less mucking around and it is easiy to use and is accurate.
Good luck mate!!
