meecar Offline
#1 Posted : Friday, 8 August 2008 7:48:36 AM(UTC)
meecar
hey all i was wondering what is holdens best 6 cyl red blue black grey etc, like power, fuel wise, reliablity etc
#2 Posted : Friday, 8 August 2008 6:13:26 PM(UTC)
They are all reliable. 202 EFI black makes the best power. 138 red is probably the most economical but in a heavier car possibly not so. If you want some power but reasonable economy a red 173 with extractors and a very mild cam is probably the go.
___
#3 Posted : Friday, 8 August 2008 7:09:16 PM(UTC)
Hi Guys.
To add to what HK1837 has said, it does depend on the weight of the car.
Ive found with stock motors in heavy cars, that a 173 doesnt use any less fuel than a 202, it just doesnt have the required torque. However, in a lighter car (e.g. LC/
Edited by user Friday, 8 August 2008 7:27:41 PM(UTC)  | Reason: Not specified
#4 Posted : Friday, 8 August 2008 7:09:16 PM(UTC)
Hi Guys.
I've found with stock motors in heavy cars, that a 173 doesn't use any less fuel than a 202, it just doesn't have the required torque. However, in a lighter car (e.g.
meecar Offline
#5 Posted : Friday, 8 August 2008 11:42:14 PM(UTC)
meecar
what would be best for a vk i have the black motor in it at the moment with extractors i should mention its carby not injected,what would be my best one to go for power, fuel doesn't really bother me as i am on gas.cheers
meecar Offline
#6 Posted : Friday, 8 August 2008 11:42:14 PM(UTC)
meecar
what would be best for a vk i have the black motor in it at the moment with extractors i should mention its carby not injected,what would be my best one to go for power, fuel doesnt really bother me as i am on gas.cheers
#7 Posted : Saturday, 9 August 2008 12:24:32 AM(UTC)
An easy conversion for a VK is to an 3.3 EFI motor. It was an option for this series, so everything is plug in.
#8 Posted : Saturday, 9 August 2008 1:02:35 AM(UTC)
Agree with Dr Terry on the EFI engine. Buy a wreck and swap it all over.
By mild cam I meant basically stock or just above it. Just an improved cam over stock that maximises torque and economy. eg Wade 259a or Crow 35613 for a carbied engine. But for t
meecar Offline
#9 Posted : Saturday, 9 August 2008 1:02:37 AM(UTC)
meecar
thanks Dr terry which one would be better black or red
meecar Offline
#10 Posted : Saturday, 9 August 2008 1:52:01 AM(UTC)
meecar
will a injection set up off a red efi or off the black efi(manifolds etc) fit a carbie black motor.
#11 Posted : Saturday, 9 August 2008 2:19:53 AM(UTC)
Hi meecar.
There is no 'Red' EFI motor. It is a bit confusing because the some VK EFI motors actually get a red rocker cover, but they are all the same 'Black' motor. The only EFI Holden 6 is the Black VK unit we are talking about.
The EFI & carby V
#12 Posted : Saturday, 9 August 2008 2:19:53 AM(UTC)
Hi meecar.
There is no Red EFI motor. It is a bit confusing because the some VK EFI motors actually get a red rocker cover, but they are all the same Black motor. The only EFI Holden 6 is the Black VK unit we are talking about.
The EFI & carby VK 3.
meecar Offline
#13 Posted : Saturday, 9 August 2008 3:05:07 AM(UTC)
meecar
Thanks for that Dr terry i never knew that the red injection was infact a black motor i guess you learn something every day. cheers
boom Offline
#14 Posted : Saturday, 9 August 2008 4:32:34 AM(UTC)
boom
if your up for a conversion, a vn-vr buick or vs ecotec is more efficient, and has more power.
In cubes we trust.
meecar Offline
#15 Posted : Saturday, 9 August 2008 4:58:34 AM(UTC)
meecar
id like to put a v6 in but its just that im no good with wiring and wouldnt know were to start with the wiring one bloke quoted me a $1000 just to do the wiring nothing else other than that no one else wants to do it.
meecar Offline
#16 Posted : Saturday, 9 August 2008 4:58:34 AM(UTC)
meecar
i'd like to put a v6 in but its just that i'm no good with wiring and wouldn't know were to start with the wiring one bloke quoted me a $1000 just to do the wiring nothing else other than that no one else wants to do it.
musksell Offline
#17 Posted : Saturday, 9 August 2008 5:04:41 AM(UTC)
musksell
seriously a v6 in a VK....? why would you do this...?
The cost of the transformation.....you'd have to love that VK..!!
just my thoughts....
musksell Offline
#18 Posted : Saturday, 9 August 2008 5:04:41 AM(UTC)
musksell
The cost of the transformation.....youd have to love that VK..!!
boom Offline
#19 Posted : Saturday, 9 August 2008 5:21:26 AM(UTC)
boom
not really musksell. a dilapidated vn is cheap mate. most parts are interchangeable.
a $200 vl is good too. most parts are interchangeable too.
In cubes we trust.
meecar Offline
#20 Posted : Saturday, 9 August 2008 5:40:32 AM(UTC)
meecar
how hard would it be to put a vl motor in,i know with a vn ya undo the struts and K frame and a few other bits and then just roll the motor out through the front and put in the vk by doing pretty much the same thing.what would be the better option.
Guest (5)
