#1 Posted : Saturday, 9 August 2008 10:59:17 PM(UTC)
GDay,
Recently had HEI die on me & now running on points. Question is, will 12v to a standard points coil it be detrimental or beneficial? I still have the old 9v lead too, so I cun run either or both. Any advice appreciated. Cheers!
#2 Posted : Sunday, 10 August 2008 3:18:09 AM(UTC)
Hi Rob.
If you still have the original ballast wiring intact, use it with a resistor style coil & points.
You could also use a standard 12V coil with your points dissy & wire to your 12 Volt supply.
Don't use the HEI coil with points, the points
#3 Posted : Sunday, 10 August 2008 3:18:09 AM(UTC)
Hi Rob.
Dont use the HEI coil with points, the points w
#4 Posted : Sunday, 10 August 2008 5:36:20 AM(UTC)
... don't mind me, I'm an idiot. I just had a closer look at the coil & is says 12v! Thanks for your help!
P.S. HEI had coil in cap so no danger there. Thanks!
#5 Posted : Sunday, 10 August 2008 5:36:20 AM(UTC)
... dont mind me, Im an idiot. I just had a closer look at the coil & is says 12v! Thanks for your help!
