tenticles Offline
#1 Posted : Tuesday, 12 August 2008 5:07:56 PM(UTC)
tenticles
i have a 3.08 salisbury diff off an HZ ute, and it has a worn hemisphere, i.e. the holes for the shafts for the spiders are worn oval
can i use another hemisphere from a different ratio diff to replace the worn one or do i need bits from the exact same diff ?
and can i just bolt it all together and go on my merry way, or will i need to have the crown and pinion gears aligned or reset or something else?
and how does the spreader work? i see the gregory manual calls for it when rebuilding but i dont have one, could maybe make one
many thanks, johnny
yes sonny, it's an HQ ute
#2 Posted : Tuesday, 12 August 2008 6:51:11 PM(UTC)
I can help with some of the questions:
Any hemisphere form 3.08-4.44 can be used (2.6 & 2.78 are different). Must also be LSD or non-LSD depending upon what you have.
You should be able to bolt it all back together, but not yourself unless you have
This page was generated in 0.017 seconds.
