#1 Posted : Thursday, 14 August 2008 7:03:31 PM(UTC)
Hi All
I just changes all the hoses heater hoses on my HQ. Problem is the lower of the two as they go into the core has a slow leak which I cant get rid of no matter how much I tighten the clamp. Core itself is ok I just dont seem to be able to get the connection to seal.
Any tips on how to rectify this??
Thanks for any tips
John
#2 Posted : Friday, 15 August 2008 1:19:30 AM(UTC)
A couple of things to try.
2 hose clamps
Narrower hose clamps
Hose clamps with a hex head that you can use a spanner/socket on
#3 Posted : Friday, 15 August 2008 2:21:32 AM(UTC)
Thanks Casper
I'll give these ideas a go and hopefully that will sort it
John
#4 Posted : Friday, 15 August 2008 2:21:32 AM(UTC)
Thanks Casper
Ill give these ideas a go and hopefully that will sort it
John
mmazz30 Offline
#5 Posted : Friday, 15 August 2008 7:32:25 AM(UTC)
mmazz30
I'm sure the heater core outlets are different diameter.
Are you using the same heater hose ID for both pipes?
If so....there is your problem.
cheers...mario
mmazz30 Offline
#6 Posted : Friday, 15 August 2008 7:32:25 AM(UTC)
mmazz30
Im sure the heater core outlets are different diameter.
cheers...mario
trubluhq Offline
#7 Posted : Friday, 15 August 2008 8:24:46 PM(UTC)
trubluhq
Mario is correct. You have to buy two diff diameter hoses to fit the HQ heater. If you have a large hose on the small fitting it wil dribble.
Cheers John
trubluhq Offline
#8 Posted : Friday, 15 August 2008 8:24:46 PM(UTC)
trubluhq
Mario is correct. You have to buy two diff diameter hoses to fit the HQ heater. If you have a large hose on the small fitting it wil dribble.'
Cheers John
#9 Posted : Saturday, 16 August 2008 4:44:05 PM(UTC)
HI Guys
From A process of elimination it would appear that the top hose is approx 3/4" while the bottom one is 5/8".
I changed the bottom from 3/4" to 5/8" and that ended the problem
John
