#1 Posted : Monday, 18 August 2008 4:14:34 AM(UTC)
Could this be a sandman panelvan
HZ 9 month 1978
Eng L 32
Tans M20
GVW 2000kg
paint code 30517 Flamenco red
trim possibly 63v
has gts dash steering wheel etc
Missing original engine and box if a sandman ball park figure of what it would be worth needs a great deal of work.
Thanks bob
#2 Posted : Monday, 18 August 2008 4:54:36 AM(UTC)
Definitely is. Depends upon rust. 1st pass guess $3000.
#3 Posted : Tuesday, 19 August 2008 10:36:36 PM(UTC)
Is it the fact that the GVW is 2000kg that makes you definetly sure it is or the colour? Thanks for the reply
#4 Posted : Wednesday, 20 August 2008 1:09:05 AM(UTC)
GVW.
adam PERTH Offline
#5 Posted : Wednesday, 20 August 2008 4:21:15 AM(UTC)
adam PERTH
bryon, would i be correect in saying that if the GVW was 2200 and Flamenco, it would be an XU-3 sandman?
(i.e. Flamenco and 2000 GVM = XX7)
WANTED: QR 662xxx
Edited by user Wednesday, 20 August 2008 4:22:00 AM(UTC)  | Reason: Not specified
HZute-efi-VS5L Offline
#6 Posted : Wednesday, 20 August 2008 4:31:14 AM(UTC)
HZute-efi-VS5L
correct adam. aslong as it had all the other sandman features. a brissy one with a gvw will have XU3 stamped on the plates. this is for all hx and hz sandmans and also the 76 year hj sandman. =)
www.stickthisdecals.com.au
#7 Posted : Wednesday, 20 August 2008 5:39:37 AM(UTC)
2200kg is the GVW for a V8 HJ-HZ van or ute, which includes XU3. Could also be a normal van.
