Fastlane
Holden Forums
Holden General Discussion
I knoe its a hlden sight but check.......
Out the price on this FORD ok so it was the first one made but geeeeez................... http://www.my105.com.au/classified.asp?id=6949"Such is life" |
"Such is life" |
Hmmmmm Windsor HO (thats the correct term not phase 1) much nicer than those ugly old Clevelands.
If at first you dont succeed then skydiving is not f |
Hmmmmm Windsor HO (that's the correct term not phase 1) much nicer than those ugly old Clevelands.
If at first you don't succeed then skydiving is not |
I had a mok up one of them with a 302 windsor in it, I was the only car that had boiling problens at Thredbo in the middle of winter. Even stuffing and packing snow around the radiator didnt help that day !!! LOL.
"Such is life" |
"Such is life" |
Heads cause that on 302W's.
A mate of mine has an XT Fairmont. It started behaving like a kettle so he replaced the heads. Problem solved but one of his new second hand heads dropped a valve and destroyed the engine.
I loaned him an engine which |
Heads cause that on 302Ws.
I loaned him an engine which d |
I thought the correct name was an XW GTHO. Phase 1 came about like series 1 does when a series 2 is released eg WB. Nice XW too. Should be close in value to any other GTHO except for the Phase IV as it's the very first one.
___________________________ |
I thought the correct name was an XW GTHO. Phase 1 came about like series 1 does when a series 2 is released eg WB. Nice XW too. Should be close in value to any other GTHO except for the Phase IV as its the very first one.
____________________________ |
Hi Guys.
Yes, I agree with Byron. Their original name was simply XW Falcon GT-HO, but when the Phase II & Phase III came out, the early ones were retrospectively called either Windsor HO or HO Phase I. I'm not sure that either of these is an 'official' |
Hi Guys.
Yes, I agree with Byron. Their original name was simply XW Falcon GT-HO, but when the Phase II & Phase III came out, the early ones were retrospectively called either Windsor HO or HO Phase I. Im not sure that either of these is an official Fo |
The correct term is XW GTHO, which is mid 1969 to March 1970. After that the XW was fitted with the 351 Cleveland in GT and GTHO. 302(4.9) Windsor was std V8 in both XW-XY, unless you specifically ordered a 5.8 ltr, then you got the 351 Cleveland in 2 bar
quote: Originally posted by we wreck 81837s only
The correct term is XW GTHO, which is mid 1969 to March 1970. After that the Edited by user Friday, 22 August 2008 12:42:14 AM(UTC)
| Reason: Not specified |
Dr Terry is one of my hero's now alongside Warren. I will now refer to him as "The DOC" is he is ok with this??? Everything you say is correct here with the exception of a few very minor details. 351W was also available in ZC Fairlane, correct, and was t
Dr Terry is one of my heros now alongside Warren. I will now refer to him as "The DOC" is he is ok with this??? Everything you say is correct here with the exception of a few very minor details. 351W was also available in ZC Fairlane, correct, and was ta
All 302-351 Cleveland had 2V heads and 2 barrel up until XC when the same carEdited by user Saturday, 23 August 2008 2:44:59 AM(UTC)
Yeah you did DOC, sorry mate, thanks for the correction on the P5 LTD.
AFTER 1972 THERE AINT NO MUSCLE CARS AND MATCHING NUMBERS ARE FOR TIMES TABLES....
XY GTHO PH111 , now thats muscle...
351W was also available in ZC Fairlane, correct, and was tagged as a "T" co |
There used to be one of these around the corner from me. The old fella sold it about a year ago. He had it since new. Looked brand new, youd swear it was 5 years old. White with brown trim. I think he got about $15,000 for it.
There used to be one of these around the corner from me. The old fella sold it about a year ago. He had it since new. Looked brand new, you'd swear it was 5 years old. White with brown trim. I think he got about $15,000 for it.
400 M Cleveland were 1st made in 1971, the 1st 351 M in 1975. The square block Cleveland came in the late XY and XA-B RPO 83 manual GT only. i do believe these blocks were made in Detroit USA. and the 1st D blocks were made in Cleveland. Then we got th
Fastlane
Holden Forums
