WB400 Offline
#1 Posted : Sunday, 24 August 2008 9:38:56 PM(UTC)
WB400
Fitting a 400 into wb ute with t350 tranny does any one know about what clearance /underbonnet iossues i mught have
#2 Posted : Monday, 25 August 2008 12:57:20 AM(UTC)
shouldnt be any? make sure that you dont use a hi rise manifold unless you want it to come thru the bonnet. a 400chev is the same outside dimensions as a 350chev(im pretty sure)some3 one else here will know more..jim
#3 Posted : Monday, 25 August 2008 1:02:21 AM(UTC)
Jim is about right. Make sure you use a WB 4 row radiator, cowl and clutch fan.
WB400 Offline
#4 Posted : Monday, 25 August 2008 1:14:38 AM(UTC)
WB400
Thanks for the info guys. Ill get some pics up when shes finished.
WB400 Offline
#5 Posted : Monday, 25 August 2008 1:14:38 AM(UTC)
WB400
Thanks for the info guys. I'll get some pics up when she's finished.
#6 Posted : Monday, 25 August 2008 10:21:56 PM(UTC)
put a big block in it..you wont regret it
AFTER 1972 THERE AINT NO MUSCLE CARS AND MATCHING NUMBERS ARE FOR TIMES TABLES....
XY GTHO PH111 , now thats muscle...
jabba Offline
#7 Posted : Monday, 25 August 2008 11:28:00 PM(UTC)
jabba
400 in HQ went ok. A reasonable manifold and carb will run fairly close to bonnet. I used a ramflo triangular filter and fitted no worries. Trying to use standaard 14" round required a drop base for the filter (and robbed about 5-10 horse according to
