#1 Posted : Sunday, 24 August 2008 11:24:21 PM(UTC)
We are attempting to use a full cable clutch, as fitted in WB models & early Commodores, in a HQ. There is a clearance issue with the top of the clutch pedal making contact with the bottom of the cowl. Has anyone performed this same conversion & what pedal did you use? Any information would be helpful.
regards kennyQ
vintageholden Offline
#2 Posted : Monday, 25 August 2008 12:08:49 AM(UTC)
vintageholden
i,m doing the same conversion soon
what clutch pedal are you using
#3 Posted : Monday, 25 August 2008 1:05:48 AM(UTC)
You need a WB V8 clutch pedal. 6cyl wont fit properly. Does the pedal you have hang down lower than the brake pedal?
#4 Posted : Monday, 25 August 2008 1:05:48 AM(UTC)
You need a WB V8 clutch pedal. 6cyl won't fit properly. Does the pedal you have hang down lower than the brake pedal?
