#1 Posted : Monday, 25 August 2008 7:23:25 AM(UTC)
Hey fellas. Im thinking of putting a bid on this coupe
http://cgi.ebay.com.au:80/ws/eBayISAPI.dll?ViewItem&item=220271703494&ssPageName=ADME:X:RTQ:AU:1123
but Im wondering if its GTS (no tags with it)??
Is there anything on the body that would identify it as a GTS?
Whats the differnce between a base model and GTS when you have no tags to go by??
Fatty
Bluez Offline
#2 Posted : Monday, 25 August 2008 8:15:07 AM(UTC)
Bluez
As far as i know its impossible to tell. All GTS's were floor shift so the factory shifter hole for Powerglide/Saginaw/Opal yet there were base models made floor shift as well. I know because i have a base model with factory floor shift.
Unless you can v
Jesse Jesse Jesse, you've not got a sense of humour!
Bluez Offline
#3 Posted : Monday, 25 August 2008 8:15:07 AM(UTC)
Bluez
As far as i know its impossible to tell. All GTSs were floor shift so the factory shifter hole for Powerglide/Saginaw/Opal yet there were base models made floor shift as well. I know because i have a base model with factory floor shift.
Unless you can ve
vintageholden Offline
#4 Posted : Monday, 25 August 2008 8:31:54 AM(UTC)
vintageholden
does it have 10 bolt diff
shifty350 Offline
#5 Posted : Monday, 25 August 2008 8:51:27 AM(UTC)
shifty350
All,
The only real way to tell the difference lies in the rear 1/4 panels as almost everything else has been altered/replaced looking at the pictures. If the quarters are the originals, then there will be telltale signs of moulding clip studs (nails) a
JYJ003 Offline
#6 Posted : Monday, 25 August 2008 9:10:31 AM(UTC)
JYJ003
I recon the dead giva way that it is a base model Monaro, not a GTS is the Column shift
#7 Posted : Monday, 25 August 2008 4:22:10 PM(UTC)
It also looks to have base model taillights and boot lid, It seems overpriced, go look at it with someone from a monaro club .
80569K Offline
#8 Posted : Monday, 25 August 2008 5:27:04 PM(UTC)
80569K
Have heard about the "guy in Queensland" who can press new tags for you.
What is the story there?
#9 Posted : Monday, 25 August 2008 6:17:46 PM(UTC)
You wouldn't easily get new tags for that coupe. I've spoken to the guys that can get them done (Harrisons), and without actual proof of the car which includes details of original damaged plates, a letter from a Monaro/Torana/whatever club and a stat dec
#10 Posted : Monday, 25 August 2008 6:17:46 PM(UTC)
You wouldnt easily get new tags for that coupe. Ive spoken to the guys that can get them done (Harrisons), and without actual proof of the car which includes details of original damaged plates, a letter from a Monaro/Torana/whatever club and a stat dec th
80569K Offline
#11 Posted : Monday, 25 August 2008 6:25:00 PM(UTC)
80569K
Thanks Byron, Im glad they are strict with it.
Not wanting to buy, one HK is enough for my pockets to cope with...LOL.
80569K Offline
#12 Posted : Monday, 25 August 2008 6:25:00 PM(UTC)
80569K
Thank's Byron, I'm glad they are strict with it.
#13 Posted : Tuesday, 26 August 2008 6:16:16 PM(UTC)
I agree with JYJ003, the base model had a three on the tree. A big coincidence is the same beige steering/gearshift column and base steering wheel as the dash paint.
Also the woodgrain doesnt match.
Just my 2 cents worth.
HkDave
#14 Posted : Tuesday, 26 August 2008 6:16:16 PM(UTC)
Also the woodgrain doesn't match.
HkDave
#15 Posted : Tuesday, 26 August 2008 7:39:16 PM(UTC)
I can't see how a decision can be made on looking at the pictures of a bitsa. What a pile of mismatched parts if ever I saw one. I like what shifty350 has said. The more you think about this and look at those pictures the only way to tell what the car was
#16 Posted : Tuesday, 26 August 2008 7:39:16 PM(UTC)
I cant see how a decision can be made on looking at the pictures of a bitsa. What a pile of mismatched parts if ever I saw one. I like what shifty350 has said. The more you think about this and look at those pictures the only way to tell what the car was
#17 Posted : Tuesday, 26 August 2008 7:51:45 PM(UTC)
The bootlid is a kingswood/non gts as it doesnt have holes for the gts boot moulding all the way across (and also has HOLDEN holes)
Hkdave
#18 Posted : Tuesday, 26 August 2008 7:51:45 PM(UTC)
The bootlid is a kingswood/non gts as it doesn't have holes for the gts boot moulding all the way across (and also has HOLDEN holes)
Hkdave
#19 Posted : Wednesday, 27 August 2008 7:13:14 AM(UTC)
thats what I thought too.
#20 Posted : Friday, 29 August 2008 9:50:40 PM(UTC)
Hi cloudy, I was having a lend of you with regard to the bootlid. We can all see that someone has drawn in the dust with their finger. The car is a mismatch at best. The answer to the question raised was completely answered by shifty350 as mentioned earli
Guest (5)
This page was generated in 0.080 seconds.
