#1 Posted : Wednesday, 27 August 2008 7:38:46 AM(UTC)
Evening all, first time on this forum so please correct me if Im out of line or off the mark :-)
I have been trying to remove the ignition barrel out of my FC, but having no luck. I have tried inserting a pin at every position and turning both left and right, but nothing seems to want free up the barrel. The FC only has "lock", "off", "on" and "start", doesn't have "accessory". The barrel has only one pin hole on the upper right. Have a new Rare Spares barrel I need to fit.
Appreciate any help or info anyone can offer. Cheers....
#2 Posted : Wednesday, 27 August 2008 7:45:14 AM(UTC)
Hi sharpeidog.
It will only work in the lock position with the key inserted. Get a paper clip or similar & feel for the little spring plunger 'thingy'. It may be stuck because it hasn't moved for over 40 years. Give it a good wriggle & push. Once it pu
#3 Posted : Wednesday, 27 August 2008 7:45:14 AM(UTC)
Hi sharpeidog.
It will only work in the lock position with the key inserted. Get a paper clip or similar & feel for the little spring plunger thingy. It may be stuck because it hasnt moved for over 40 years. Give it a good wriggle & push. Once it pushe
#4 Posted : Wednesday, 27 August 2008 8:01:01 AM(UTC)
Thanks mate. Must admit I havent tried that. I have been using a very thin Allen Key and it seemed pretty solid when I inserted it. Will try it again in the lock position and carefully use a little more force.
#5 Posted : Wednesday, 27 August 2008 8:01:01 AM(UTC)
Thanks mate. Must admit I haven't tried that. I have been using a very thin Allen Key and it seemed pretty solid when I inserted it. Will try it again in the lock position and carefully use a little more force.
#6 Posted : Wednesday, 27 August 2008 8:03:51 AM(UTC)
No luck, seems to push in o.k. but I cant get it to turn further left. Have sprayed the hell out of it with dry lube as well. Will have to try again tomorrow.
#7 Posted : Wednesday, 27 August 2008 8:03:51 AM(UTC)
No luck, seems to push in o.k. but I can't get it to turn further left. Have sprayed the hell out of it with dry lube as well. Will have to try again tomorrow.
Custom Offline
#8 Posted : Wednesday, 27 August 2008 8:31:46 AM(UTC)
Custom
Maybe try a small nail and use pliers to make sure you are pressing the pin right down. If you've given it a good spray you may then have to wriggle it round enough but it will go.
Good Luck.
Custom Offline
#9 Posted : Wednesday, 27 August 2008 8:31:46 AM(UTC)
Custom
Maybe try a small nail and use pliers to make sure you are pressing the pin right down. If youve given it a good spray you may then have to wriggle it round enough but it will go.
Good Luck.
#10 Posted : Wednesday, 27 August 2008 5:41:10 PM(UTC)
they can be a prick of a thing...keep trying
AFTER 1972 THERE AINT NO MUSCLE CARS AND MATCHING NUMBERS ARE FOR TIMES TABLES....
XY GTHO PH111 , now thats muscle...
sharpeidog Offline
#11 Posted : Thursday, 28 August 2008 2:50:41 AM(UTC)
sharpeidog
Got it, but what an absolute mongrel of a thing.......
sharpeidog Offline
#12 Posted : Thursday, 28 August 2008 3:36:46 AM(UTC)
sharpeidog
O.k., next question.... The existing ignition switch has posts for 2 ignition wires, i.e IGN1 and IGN2. IGN1 makes circuit in the "on" position, but IGN2 makes circuit in the "start" position and goes to the neutral safety switch on the trans selector. Th
sharpeidog Offline
#13 Posted : Thursday, 28 August 2008 3:43:18 AM(UTC)
sharpeidog
Aaaargh!!!!! And now I find the original chrome ring nut is a different thread to the replacement switch??????? I'm just not having a good day....
sharpeidog Offline
#14 Posted : Thursday, 28 August 2008 3:43:18 AM(UTC)
sharpeidog
Aaaargh!!!!! And now I find the original chrome ring nut is a different thread to the replacement switch??????? Im just not having a good day....
#15 Posted : Thursday, 28 August 2008 4:23:15 AM(UTC)
Hi sharpeidog.
Your old switch doesnt sound to me, to be an original FC ignition switch. The original has only 4 screw type terminals & none of then are marked IGN1 or IGN2. Your old one sounds like an EH to HG type.
The posts on the switch are iden
#16 Posted : Thursday, 28 August 2008 4:23:15 AM(UTC)
Hi sharpeidog.
Your old switch doesn't sound to me, to be an original FC ignition switch. The original has only 4 screw type terminals & none of then are marked IGN1 or IGN2. Your old one sounds like an EH to HG type.
sharpeidog Offline
#17 Posted : Thursday, 28 August 2008 4:49:38 AM(UTC)
sharpeidog
Yes I should have said spade terminals rather than posts. Ok, sounds like its been altered at some stage and I will have to wire according to the new switch. Its all good I guess, except for the safety switch, which I will have to sus out. Apologies, I sh
sharpeidog Offline
#18 Posted : Thursday, 28 August 2008 4:49:38 AM(UTC)
sharpeidog
Yes I should have said spade terminals rather than posts. Ok, sounds like it's been altered at some stage and I will have to wire according to the new switch. It's all good I guess, except for the safety switch, which I will have to sus out. Apologies, I
sharpeidog Offline
#19 Posted : Friday, 29 August 2008 7:01:09 AM(UTC)
sharpeidog
Sorted the ignition today, well at least until I do a full rewire.... Thanks for the info guys, appreciate it.
This page was generated in 0.083 seconds.
