clubby677 Offline
#1 Posted : Wednesday, 27 August 2008 10:56:21 AM(UTC)
clubby677
Is there a way to identify what type of 4 speed is in the car when its all bolted up to V8 and in car ? M20 M21 M22
He who dies with the most toys wins!
#2 Posted : Wednesday, 27 August 2008 4:17:36 PM(UTC)
If its Aussie 4 speed you are talking about then no, but it shouldnt be an M22 behind a V8. If you know your diff ratio and tyre size and speedo is correct you can work it out by revs vs speed in each gear 1st-3rd.
_____________________________________
#3 Posted : Wednesday, 27 August 2008 4:17:36 PM(UTC)
If it's Aussie 4 speed you are talking about then no, but it shouldn't be an M22 behind a V8. If you know your diff ratio and tyre size and speedo is correct you can work it out by revs vs speed in each gear 1st-3rd.
