vintageholden Offline
#1 Posted : Thursday, 28 August 2008 9:18:26 AM(UTC)
vintageholden
anyone know where the small brass pipe goes
car runs well just wondered what it is for
can post photos if wanted
HZ-GED Offline
#2 Posted : Thursday, 28 August 2008 1:04:43 PM(UTC)
HZ-GED
It may be for the pre-start priming if required. My converter has a solenoid in line to the carby with a brass fitting at the converter. May be the same? Not needed most of the time, probably why its not connected. If you post a picture that would help.
HZ-GED Offline
#3 Posted : Thursday, 28 August 2008 1:04:43 PM(UTC)
HZ-GED
It may be for the pre-start priming if required. My converter has a solenoid in line to the carby with a brass fitting at the converter. May be the same? Not needed most of the time, probably why it's not connected. If you post a picture that would help.
#4 Posted : Friday, 29 August 2008 12:55:50 AM(UTC)
vintageholden
http://www.flickr.com/photos/29980619@N08/?saved=1
the first photo of the mixer has a brass pipe near top of elbow
Edited by user Friday, 29 August 2008 12:56:21 AM(UTC)  | Reason: Not specified
The Yeti Offline
#5 Posted : Friday, 29 August 2008 2:39:14 AM(UTC)
The Yeti
been a long long time since I playied with gas (sad considerign my back ground) but form memory it goes to manifold vacume to hold the diaphram off at idle
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
The Yeti Offline
#6 Posted : Friday, 29 August 2008 2:39:14 AM(UTC)
The Yeti
See The Yetis Chev build at
#7 Posted : Friday, 29 August 2008 3:31:48 AM(UTC)
vintageholden
thanks
i was told to block it off......now idling fast
