meecar Offline
#1 Posted : Friday, 29 August 2008 6:35:51 AM(UTC)
meecar
hey all, i have a 253 with a m21 and i want to go auto what would be the best, looking to go 4 speed auto maybe vn 2 vs not sure yet, what would be the better one to go. cheers
boom Offline
#2 Posted : Friday, 29 August 2008 7:20:07 AM(UTC)
boom
turbo pattern doesnt bolt up to your block.
In cubes we trust.
meecar Offline
#3 Posted : Friday, 29 August 2008 7:34:02 AM(UTC)
meecar
what would bolt up using a adaptor plate and not needing to much stuffing around with computers and wires.
#4 Posted : Friday, 29 August 2008 7:52:55 AM(UTC)
Trimatic and swap to taller diff.
#5 Posted : Friday, 29 August 2008 11:27:12 PM(UTC)
Easiest four speeder would be a VN or VP V8 box. You can also buy an adapter to fit a VN or VP V6 box (cheaper box but possibly more expensive conversion kit).
Those two models don't have an electronic auto but still require some wiring to operate th
#6 Posted : Friday, 29 August 2008 11:27:12 PM(UTC)
Those two models dont have an electronic auto but still require some wiring to operate the
clubby677 Offline
#7 Posted : Friday, 5 September 2008 10:51:56 AM(UTC)
clubby677
VN to VP as jim5.0 said but use (V6t700)the kit is around $500 from CRS in victoria and a sinch to fit but you may need to get the tail shaft shortend, as for the lock up you can buy a kit for $200 that will do it automaticly or rig up a switch yourself w
Edited by user Friday, 5 September 2008 6:05:51 PM(UTC)  | Reason: Not specified
He who dies with the most toys wins!
GTS308HZ Offline
#8 Posted : Saturday, 6 September 2008 6:35:50 AM(UTC)
GTS308HZ
Depending on your engine mods (bored, race cam and so forth) why not try a 2 speed power glide, unbreakable.
Pete
#9 Posted : Saturday, 6 September 2008 8:14:18 PM(UTC)
308.....t400...308diff...i think is the best(affordable combo)by time you do all the other stuff ,just get a turbo block,leave the car as is and start a build up on the combo ,just my opinion..cheers(too lazy to log on)
meecar Offline
#10 Posted : Monday, 8 September 2008 9:44:03 PM(UTC)
meecar
thanks everyone for advice and opinions will go and price a auto and get to work. cheers
