is the tailshaft for HQ sedan the same length for 6 cyl/ m20/bango as 8cyl/m20/salisbury 10 bolt holden? also what is the difference in length from sedan to wagon? I am doing a conversion thanks for helping
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
Wagon/ute/van/statesman are all the same length. Sedan is shorter and tonner is longer. Tailshaft for the combos you describe are the same length but rear uni is smaller for 6cyl.
_______________________________________________________ If we all had t |
Hi Guys. I beg to differ Byron. The front of a V8 Salisbury diff protrudes further forward. I know its not that much, but the V8 tailshaft will be 0.76" (about 3/4") shorter. Wagon/ute/van/Statesman tailshaft is 3" longer than SWB sedan & coupe.
Edited by user Friday, 29 August 2008 8:16:18 AM(UTC)
| Reason: Not specified |
Hi Guys. I beg to differ Byron. The front of a V8 Salisbury diff protrudes further forward. I know it's not that much, but the V8 tailshaft will be 0.76" (about 3/4") shorter. Wagon/ute/van/Statesman tailshaft is 3" longer than SWB sedan & coupe. Edited by user Friday, 29 August 2008 8:16:18 AM(UTC)
Yes my bad. I should learn to read the question again after ive typed before I hit the submit button. I read the 6cyl/M20 and V8/M20 bit and assumed both diffs were banjos where the question very clearly says salisbury AND also 10 bolt.
_______________ |
Yes my bad. I should learn to read the question again after i've typed before I hit the submit button. I read the 6cyl/M20 and V8/M20 bit and assumed both diffs were banjos where the question very clearly says salisbury AND also 10 bolt.
______________ |
