BAD WB Offline
#1 Posted : Tuesday, 2 September 2008 2:27:56 AM(UTC)
BAD WB
Wandering if there is any advantages of using chev 6" rods over 5.7" in a 383, been looking at stroker kits not sure which way to go. Any info would be great.
#2 Posted : Tuesday, 2 September 2008 3:07:06 AM(UTC)
the longer the rod (increase rod to stroke ratio)the longer the piston stays around TDC and you get better combustion and mechanical advantage. The down-side is that your peak power is produced higher up the rev range
