#1 Posted : Thursday, 4 September 2008 2:29:11 AM(UTC)
my trimatic loses drive when i first drive it then when it takes up its fine for the rest of the day does anyone know why it loses drive in this way ? its behind a 202 thanks
#2 Posted : Thursday, 4 September 2008 2:35:08 AM(UTC)
Probably needs a rebuild. The seals go hard and it takes a bit of heat to get into them before they seal.
GTS308HZ Offline
#3 Posted : Saturday, 6 September 2008 6:39:19 AM(UTC)
GTS308HZ
I lose my drive in my trimatic first thing in the morning and it is behind a 253. I am pretty sure it is due to the transmission oil not being hot enough to get into gear.I am not a mechanic but no enough to get out of trouble. My trimatic has been fully
#4 Posted : Tuesday, 9 September 2008 12:22:48 AM(UTC)
You have nothing to lose except about $12 by adding a bottle of Nulon or similar auto transmission conditioner.
If at first you dont succeed then skyd
#5 Posted : Tuesday, 9 September 2008 12:22:48 AM(UTC)
If at first you don't succeed then sky
This page was generated in 0.144 seconds.
