bundybluedog Offline
#1 Posted : Sunday, 7 September 2008 7:29:15 AM(UTC)
bundybluedog
Another stroker question for you all. is there much diferance in torque between the 355 and 330? i heard the power diferance is minimal its just cheaper now to go 355 because there is so much stuff on the market for them.
#2 Posted : Sunday, 7 September 2008 7:39:52 AM(UTC)
CORRECT
AFTER 1972 THERE AINT NO MUSCLE CARS AND MATCHING NUMBERS ARE FOR TIMES TABLES....
XY GTHO PH111 , now thats muscle...
#3 Posted : Sunday, 7 September 2008 11:15:47 PM(UTC)
Basically like a 327 to 350 Chev, which is essentially what you are doing as the two Holden strokers are the same bore/stroke as the Chevs. From memory you were going to use early heads so either will be pretty torquey due to the smaller ports.
_______
#4 Posted : Sunday, 7 September 2008 11:33:32 PM(UTC)
bundybluedog
From what im told a 330 is a 0.060" ofset ground holden crank with chev 2.00" small journal 5.700" rods rods and 327 pistons. with no need to grind block for clearance. but the rods and bearings will have to be machined to suit a holden crank. so by the t
boom Offline
#5 Posted : Monday, 8 September 2008 12:49:20 AM(UTC)
boom
ive calculated all costs many times, and the best option is either stock stroke or 355. cheaper to go COME 383 than 330.
In cubes we trust.
#6 Posted : Monday, 8 September 2008 12:53:42 AM(UTC)
This is how I understand it to work. The Holden 327 stroker is an offset grind, but the actual stroke depends upon the journals on the target crank. If its standard and you grind to undersize 2" you can get more stroke, but they normally end up at about 3
#7 Posted : Monday, 8 September 2008 12:53:42 AM(UTC)
This is how I understand it to work. The Holden 327 stroker is an offset grind, but the actual stroke depends upon the journals on the target crank. If it's standard and you grind to undersize 2" you can get more stroke, but they normally end up at about
#8 Posted : Monday, 8 September 2008 4:40:12 AM(UTC)
The 350 Chev isnt the most popular V8 in the history of the world for no reason...
Great bore and stroke ratio.
Great power and torque.
The 327 only lasted a few years. The 350 goes on and on.
Why not turn your crummy 308 into a 350.
320 M
#9 Posted : Monday, 8 September 2008 4:40:12 AM(UTC)
The 350 Chev isn't the most popular V8 in the history of the world for no reason...
320
#10 Posted : Monday, 8 September 2008 5:30:15 AM(UTC)
just put a big block in it, you wont regret it..pffft@plastic strokers by 2 brothers in caulfield, as more cubes said above, the factory dont spend millions of $$$$$$$$ to do something,even if its not perfect, to some some dude in a backyard machine shop
musksell Offline
#11 Posted : Monday, 8 September 2008 7:13:52 AM(UTC)
musksell
My thoughts bundybluedog...
the way I see it.....
the 330/327 will put less strain on your drive train, which no one else here seems to have taken into the equation.
Also the 330 is really just modernising the 308, where as the 350 really is a whole
#12 Posted : Tuesday, 9 September 2008 4:34:37 AM(UTC)
bundybluedog
the best price i could get for a 355 was an eagle kit for around 2300 fully ballanced. the 330 stroker is about $1100. $350 for the regrind $250 for new scat rods about $150 for speed pro pistons about $60 to get them both sent from the states and $250 f
#13 Posted : Tuesday, 9 September 2008 5:40:26 AM(UTC)
COME 350 kit is $1995.
#14 Posted : Tuesday, 9 September 2008 5:54:04 AM(UTC)
bundybluedog
355 CRANK, "I" BEAM ROD, CAST PISTON BALANCED KIT (INCLUDES RINGS, ROD & MAIN
BEARINGS)
2,530
this is the price i got of there website.
#15 Posted : Tuesday, 9 September 2008 6:29:16 AM(UTC)
Bundy
I have a Holden offset ground stroker crank here machined ready to go and a block machined to suit if you are interested. Email me if interested. Block is a trimatic pattern though.
If we
boom Offline
#16 Posted : Tuesday, 9 September 2008 9:48:25 PM(UTC)
boom
Originally posted by musksell
and if so why did chev change it in 93...maybe it was 96..?
someone help me here...
#17 Posted : Tuesday, 9 September 2008 11:10:02 PM(UTC)
August 96 was the release date of the much anticpated LS1 in the US
#18 Posted : Thursday, 11 September 2008 6:08:17 AM(UTC)
bundybluedog
hey boom i remember you saying about a company that makes custom head gaskets but i cannot find the thread. wat was that.
#19 Posted : Thursday, 11 September 2008 4:37:52 PM(UTC)
bundybluedog
sent you an email byron.
knute Offline
#20 Posted : Friday, 12 September 2008 2:28:47 AM(UTC)
knute
ridgecrest engineering
03 59814334
Guest (11)
This page was generated in 0.082 seconds.
