I got a M22 out of an HQ tonner for some reason theres a swich plug on 3-4 shifter fork shaft can any one tell what this is for ? |
If I agreed with you we`d both be wrong. |
ADR27A pollution equipment. It's a switch that closes in 4th gear and drives a solenoid up on the engine that switches the vacuum advance on. Found on HX onwards.
_______________________________________________________ If we all had the same (good) ta |
ADR27A pollution equipment. Its a switch that closes in 4th gear and drives a solenoid up on the engine that switches the vacuum advance on. Found on HX onwards.
_______________________________________________________ If we all had the same (good) tas |
Thanks for that info mate. Will a 3 speed shifter cover fit on a 4 speed ? |
I think so.
