one tonner man Offline
#1 Posted : Sunday, 7 September 2008 10:52:10 PM(UTC)
one tonner man
I got a M22 out of an HQ tonner for some reason theres a swich plug on 3-4 shifter fork shaft can any one tell what this is for ?
If I agreed with you we`d both be wrong.
#2 Posted : Sunday, 7 September 2008 11:10:23 PM(UTC)
ADR27A pollution equipment. It's a switch that closes in 4th gear and drives a solenoid up on the engine that switches the vacuum advance on. Found on HX onwards.
If we all had the same (good) ta
#3 Posted : Sunday, 7 September 2008 11:10:23 PM(UTC)
ADR27A pollution equipment. Its a switch that closes in 4th gear and drives a solenoid up on the engine that switches the vacuum advance on. Found on HX onwards.
If we all had the same (good) tas
#4 Posted : Monday, 8 September 2008 5:15:24 AM(UTC)
one tonner man
Thanks for that info mate.
Will a 3 speed shifter cover fit on a 4 speed ?
#5 Posted : Monday, 8 September 2008 6:55:41 AM(UTC)
I think so.
This page was generated in 0.022 seconds.
