one tonner man Offline
#1 Posted : Monday, 8 September 2008 10:27:50 AM(UTC)
one tonner man
Just put my M22 in tonight whent for a drive when going to 1st the shifter trys to pop backin to neutral and when going to 2nd it is in neutral. I had adjusted 1st & 2nd rod befor putting in. I know I need to rejust the rod but i cant see why theres no 2nd when 1st is under adjusted ?
If I agreed with you we`d both be wrong.
#2 Posted : Tuesday, 9 September 2008 8:03:51 AM(UTC)
Maybe the small lever on the side of the box is loose/flogged out?
#3 Posted : Tuesday, 9 September 2008 8:55:14 AM(UTC)
one tonner man
Trunds out to be the 3 speed side cover I put on it the 1st & 2nd shifter fork shaft has a different angle to a four speed shaft. Pulling it out in the weekend and have a look then.
#4 Posted : Tuesday, 9 September 2008 4:18:05 PM(UTC)
Is the cover the same but the selector fork different?
#5 Posted : Thursday, 11 September 2008 9:31:12 AM(UTC)
one tonner man
Cover is the same and so are the shifer fork shaft. Its the detent cams and selector shaft fork that is different from what I can see.
