6pak Offline
#1 Posted : Wednesday, 10 September 2008 9:27:03 AM(UTC)
6pak
Hi Folks. I'm hoping someone can give me some clues regarding the fuel gauge in my ZD Fairlane. I have had the gauge fixed up when the gauge cluster was reconditioned in the rebuild, I have just had a sender unit rebuilt with all new components and installed it but nothing is happening at the gauge. If I check the voltage at the wire to the sender unit with a multimeter how many volts should I be getting as a starting point? Any info about other things to check would be appreciated.
#2 Posted : Thursday, 11 September 2008 1:18:42 AM(UTC)
Is the sender unit earthed? Remove the wire from the sender and earth it whilst someone watches what the fuel gauge does (with the ignition on of course).
There should be a metal clip that connects the main fuel line to the tank outlet which carri
Edited by user Thursday, 11 September 2008 1:20:41 AM(UTC)  | Reason: Not specified
6pak Offline
#3 Posted : Monday, 15 September 2008 7:54:06 AM(UTC)
6pak
Hi Jim, Thanks for your input. I've tested the wire by earthing it and nothing happened. I have also put a multimeter on the wire and it isn't showing any current. I'm now pulling the dash facia out to have a better look at things back there. I have a s
www.earlyfalcons.com Offline
#4 Posted : Monday, 15 September 2008 8:04:40 AM(UTC)
not sure on the ZD, but in the XK-XP Falcons, the fuel gauge ran off the Temp gauge, so if the temp gauge was faulty the fuel one wouldn't work. I think that was the order.
6pak Offline
#5 Posted : Tuesday, 16 September 2008 8:53:54 AM(UTC)
6pak
Hi, You're dead right there. The wiring diagram shows the power feed running via the temp gauge. The temp gauge is working fine as that was also sorted out in the dash recon so I'm now wondering if there is a break in the power supply from the temp to t
6pak Offline
#6 Posted : Sunday, 21 September 2008 10:51:29 PM(UTC)
6pak
It turned out to be a wiring connector in the system working its way lose. It probably happened with all of the activity under the dash, putting everything back in...it's always the little things that catch you. :)
