HQforme Offline
#1 Posted : Saturday, 13 September 2008 5:00:22 AM(UTC)
HQforme
Anyone with any advice on areas to pay special attention to when looking at EJ Holden sedans?
"Silly modern cars"
#2 Posted : Saturday, 13 September 2008 5:03:51 AM(UTC)
yep if the ad says EJ for sale..... unless it says prem you would be better off buying a HR to HQ
there is nothing pretty about drum brakes
#3 Posted : Saturday, 13 September 2008 5:08:16 AM(UTC)
yes make shore the siggy liter works
#4 Posted : Saturday, 13 September 2008 6:17:09 PM(UTC)
rust in the undercarraige, y-frames, boot,floors. plus rust you can see panels.
if resprayed check for bog with a small magnet, 138 is not a fast motor but pretty reliable in good cond.
perfomance parts are available for the 138 if your keeping it. I re
HQforme Offline
#5 Posted : Sunday, 14 September 2008 5:39:12 AM(UTC)
HQforme
Hqgts...im already in an HQ mate! Id be looking at fitting a later-model front end anyway.
Cloudy, thanks for the tips. I always take a magnet with me. This cars got a red motor and 5speed box already, so i plant to pull the warm 202 from my HQ, work i
"Silly modern cars"
HQforme Offline
#6 Posted : Sunday, 14 September 2008 5:39:12 AM(UTC)
HQforme
Hqgts...i'm already in an HQ mate! I'd be looking at fitting a later-model front end anyway.
Cloudy, thanks for the tips. I always take a magnet with me. This car's got a red motor and 5speed box already, so i plant to pull the warm 202 from my HQ, wor
"Silly modern cars"
#7 Posted : Sunday, 14 September 2008 6:19:02 AM(UTC)
hi, in addition to the rust places mentioned above, check the metal around the inside front and rear windscreens at the corners, a common place where they go, cheers f.
#8 Posted : Sunday, 14 September 2008 7:34:12 AM(UTC)
HQGTS are u for real????
why is it that most "OLD" holden forums seem to assume that old holden only means from HQ-WB????
mate an EJ or EH is worth 5 HQs
the guy was only asking for advise, he wasnt asking to be bagged
#9 Posted : Sunday, 14 September 2008 7:34:12 AM(UTC)
mate an EJ or EH is worth 5 HQ's
Custom Offline
#10 Posted : Sunday, 14 September 2008 8:15:56 AM(UTC)
Custom
Just be a realist, you are buying a 45 year old car, expect a few problems and you wont be to dissapointed.
Good luck.
Custom Offline
#11 Posted : Sunday, 14 September 2008 8:15:56 AM(UTC)
Custom
Just be a realist, you are buying a 45 year old car, expect a few problems and you won't be to dissapointed.
Good luck.
#12 Posted : Sunday, 14 September 2008 8:40:50 AM(UTC)
Hi , youll be hard pressed to buy one you wont have to work on.just make sure the work isnt too expensive or you can do most yourself,ps the magnet trick only works sometimes but i always do it.There is metal in some of the new bog out there,the best comm
#13 Posted : Sunday, 14 September 2008 8:40:50 AM(UTC)
Hi , you'll be hard pressed to buy one you wont have to work on.just make sure the work isn't too expensive or you can do most yourself,ps the magnet trick only works sometimes but i always do it.There is metal in some of the new bog out there,the best co
HQforme Offline
#14 Posted : Monday, 15 September 2008 6:51:49 AM(UTC)
HQforme
Cheers all...im well aware of the pitfalls involved with buying old cars. Im capable of all mechanical work, as ive done with this HQ and my Alfa before that, just body work that gets me.
I viewed this car, its nice. Interiors schmick (new) motor start
"Silly modern cars"
HQforme Offline
#15 Posted : Monday, 15 September 2008 6:51:49 AM(UTC)
HQforme
Cheers all...i'm well aware of the pitfalls involved with buying old cars. I'm capable of all mechanical work, as i've done with this HQ and my Alfa before that, just body work that gets me.
I viewed this car, it's nice. Interior's schmick (new) motor
"Silly modern cars"
Custom Offline
#16 Posted : Monday, 15 September 2008 7:36:58 AM(UTC)
Custom
You won't have any problems with the fibre glass guards with RWC.
Fibre glass guards are a real option these days as good steel guards are just too expensive if you can't prep a set yourself. If fitted properly there are only visually a couple of ways yo
Custom Offline
#17 Posted : Monday, 15 September 2008 7:36:58 AM(UTC)
Custom
You wont have any problems with the fibre glass guards with RWC.
Fibre glass guards are a real option these days as good steel guards are just too expensive if you cant prep a set yourself. If fitted properly there are only visually a couple of ways you
#18 Posted : Monday, 15 September 2008 8:26:35 PM(UTC)
The rear apron under the bumper as you described is also available as a new fibreglass panel so the one you are looking at probably has this in glass if the front guards are.
#19 Posted : Tuesday, 16 September 2008 2:15:47 AM(UTC)
I've had a few EJ's & a common area were rust can develop unnoticed, is were the top of the front subframe attaches to the body shell, it can look totally solid from within the wheel arch, but if you look up behind the glove box & above the excellerator,
#20 Posted : Tuesday, 16 September 2008 2:15:47 AM(UTC)
Ive had a few EJs & a common area were rust can develop unnoticed, is were the top of the front subframe attaches to the body shell, it can look totally solid from within the wheel arch, but if you look up behind the glove box & above the excellerator, in
Guest (5)
This page was generated in 0.109 seconds.
