HQforme Offline
#1 Posted : Monday, 15 September 2008 6:57:34 AM(UTC)
HQforme
As i drive, theres a constant high-pitched ringing noise...the sort made by something metallic on a spinning shaft if it's loose. I know that should pigeon-hole it, but i can't find anything. It's a shrill, high-tingle.
Then, today, sitting it idle, a HORRIBLE noise. My neighbour heard it from in his house and came out to see what it was. Imagine if you had a lump of lead being flung around your bellhousing. A deeper clunking, random, but constant and heavy.
Then it dissappeared by the time i got the car in the garage and up on stands. Pulled the pan off the bellhousing, can find nothing. Start the car up, can't make it rattle anymore.
Engine has been idling a liiiittle rough of late, but seems to run fine.
Anything, anyone?
Edited by user Monday, 15 September 2008 6:58:53 AM(UTC)  | Reason: Not specified
"Silly modern cars"
Custom Offline
#2 Posted : Monday, 15 September 2008 7:27:39 AM(UTC)
Custom
Is the car an auto.
If so I would be pointing the finger at the Torque Converter.
bundybluedog Offline
#3 Posted : Monday, 15 September 2008 7:36:36 AM(UTC)
bundybluedog
convertor pumps wine when on the way out and fins can brake of inside them and cam make the engine and gearbox shake.
Custom Offline
#4 Posted : Monday, 15 September 2008 7:39:54 AM(UTC)
Custom
Hey, have you bought that EJ yet???
HQforme Offline
#5 Posted : Wednesday, 17 September 2008 9:29:21 AM(UTC)
HQforme
These things are so funny.
Morning after posting, i found it. Its a manual, and all original (3 on tree) so everythings worn. To the point where, popping it in neutral, it wasnt quite..and the gears clashed as the linkages shook ever so slightly...caus
"Silly modern cars"
HQforme Offline
#6 Posted : Wednesday, 17 September 2008 9:29:21 AM(UTC)
HQforme
Morning after posting, i found it. It's a manual, and all original (3 on tree) so everything's worn. To the point where, popping it in neutral, it wasn't quite..and the gears clashed as the linkages shook ever so slightly...c
"Silly modern cars"
Custom Offline
#7 Posted : Wednesday, 17 September 2008 4:55:08 PM(UTC)
Custom
Sound good that you've sorted it.
Once you get that EJ register here http://forum.ejehclubqld.com/ehclub/forum/
One of the coolest easy going forums around. Great place to hang out.
Custom Offline
#8 Posted : Wednesday, 17 September 2008 4:55:08 PM(UTC)
Custom
Sound good that youve sorted it.
