roy1126 Offline
#1 Posted : Monday, 15 September 2008 9:00:12 AM(UTC)
roy1126
Hi all
Since starting my rebuild on a HZ everyone is trying to persuade me to ditch the 253 and go the 308. I havent got a problem with this. My question is, are there any major alterations to the rest of the car because as I understand it, the 308 should just slot right in.
Thanks.
Holdenon Offline
#2 Posted : Monday, 15 September 2008 1:26:50 PM(UTC)
Holdenon
Roy,
Depending on what you want to do, there is nothing wrong with the 253. I've had both over the years. If you want to impress your mates and smoke the rear wheels - go the 308. If you want a good reliable V8 for crusing and good highway mileage - st
Holdenon Offline
#3 Posted : Monday, 15 September 2008 1:26:50 PM(UTC)
Holdenon
Roy,
Depending on what you want to do, there is nothing wrong with the 253. Ive had both over the years. If you want to impress your mates and smoke the rear wheels - go the 308. If you want a good reliable V8 for crusing and good highway mileage - sti
#4 Posted : Monday, 15 September 2008 4:10:03 PM(UTC)
308 wil bolt straight in if it's a trimatic/4speed block. You can use a Turbo pattern block but you'll either have to change gearbox or bellhousing to suit.
If we all had the same (good) taste, w
#5 Posted : Monday, 15 September 2008 4:10:03 PM(UTC)
308 wil bolt straight in if its a trimatic/4speed block. You can use a Turbo pattern block but youll either have to change gearbox or bellhousing to suit.
If we all had the same (good) taste, who
#6 Posted : Monday, 15 September 2008 4:16:32 PM(UTC)
The HJ 308 was 240-250 bhp depending on who`s book you read. the 253 was 185 bhp.
The Yeti Offline
#7 Posted : Tuesday, 16 September 2008 2:47:35 AM(UTC)
The Yeti
I'd stick with the 253, if you want to impress your mates buy some of those wissbacng chrome rocker covers with 308 on them and stick a 4bbl on it they'll never know hte difference,
if you want to change the engine wack in a 350 chev you will find the
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
The Yeti Offline
#8 Posted : Tuesday, 16 September 2008 2:47:35 AM(UTC)
The Yeti
Id stick with the 253, if you want to impress your mates buy some of those wissbacng chrome rocker covers with 308 on them and stick a 4bbl on it theyll never know hte difference,
if you want to change the engine wack in a 350 chev you will find the c
slobey Offline
#9 Posted : Tuesday, 16 September 2008 5:21:29 AM(UTC)
slobey
I would stick with the 253 unless youre going to rebuild a 308. Ive had both and the 253 revs harder and IMO is more fun to drive.
A few moths ago I took off for a cruise and forgot to turn the thermos on (long story), needless to say I almost cooked
slobey Offline
#10 Posted : Tuesday, 16 September 2008 5:21:29 AM(UTC)
slobey
I would stick with the 253 unless you're going to rebuild a 308. I've had both and the 253 revs harder and IMO is more fun to drive.
#11 Posted : Tuesday, 16 September 2008 6:11:01 AM(UTC)
Always wondered about the old "253's rev harder" myth. It may be true for some reason but it sounds like an urban myth to me as it goes against conventional engine physics. The further an engine goes oversquare the harder it should rev. Examples 302 Chev
#12 Posted : Tuesday, 16 September 2008 6:11:01 AM(UTC)
Always wondered about the old "253s rev harder" myth. It may be true for some reason but it sounds like an urban myth to me as it goes against conventional engine physics. The further an engine goes oversquare the harder it should rev. Examples 302 Chev o
#13 Posted : Tuesday, 16 September 2008 6:18:36 AM(UTC)
HK1837,you right its a myth depends on what u put in to how they spin,balance anything an it spins better as we all know.
#14 Posted : Tuesday, 16 September 2008 7:14:06 AM(UTC)
Best idea is go and buy yourself a boat. Then you can weld a chain to the 253 and use it as an anchor..!!
308 is the way to go. You will pay just as much rego with a 253 with loads less grunt.
If you want to save fuel, go buy a Barina...
JBM Offline
#15 Posted : Tuesday, 16 September 2008 9:09:17 AM(UTC)
JBM
253s have lighter pistons (smaller bore) and therefore doesnt need huge counterweights on the crank, the rotating assembly is lighter on 2 counts and can rev faster than a 308.
In theory.
James
roy1126 Offline
#16 Posted : Tuesday, 16 September 2008 9:57:09 AM(UTC)
roy1126
Thanks all for the replies. I think I've decided to go the 308. Either way I was going to rebuild the 253 or the 308 so I may as well go the 308.
My HZ has the drum rear end and the trimatic. To register it in WA, does anything like the brakes or anythi
roy1126 Offline
#17 Posted : Tuesday, 16 September 2008 9:57:09 AM(UTC)
roy1126
Thanks all for the replies. I think Ive decided to go the 308. Either way I was going to rebuild the 253 or the 308 so I may as well go the 308.
My HZ has the drum rear end and the trimatic. To register it in WA, does anything like the brakes or anythin
#18 Posted : Tuesday, 16 September 2008 3:58:13 PM(UTC)
You dont need to change anything on the car, except maybe a better exhaust if it only has an original type single system and possibly put a 3 row radiator in it. These are only about $350 new, and the original fan shrouds are cheap from Rare Spares for us
#19 Posted : Tuesday, 16 September 2008 3:58:13 PM(UTC)
You don't need to change anything on the car, except maybe a better exhaust if it only has an original type single system and possibly put a 3 row radiator in it. These are only about $350 new, and the original fan shrouds are cheap from Rare Spares for u
knute Offline
#20 Posted : Tuesday, 16 September 2008 6:18:03 PM(UTC)
knute
what is the difference between VK and HQ rods please ?
Guest (6)
This page was generated in 0.131 seconds.
