#1 Posted : Tuesday, 16 September 2008 5:43:27 AM(UTC)
hi, im lowering my vl myself, brought brand new springs and had everything readdy to go, i think i read somewhere that i may need an adjustable pannah bar or something? because i have 19z... can anyone confirm this, am i able to do it myself?
#2 Posted : Tuesday, 16 September 2008 7:13:52 AM(UTC)
As you lower the car, the stock panhard rod pushes the diff over towards the drivers side, which can cause your tyres to rub the guards.
An adjustable panhard rod allows you to re-centre your diff, so the tyres dont rub (or at least rub less).
Its an
#3 Posted : Tuesday, 16 September 2008 7:13:52 AM(UTC)
As you lower the car, the stock panhard rod pushes the diff over towards the driver's side, which can cause your tyres to rub the guards.
An adjustable panhard rod allows you to re-centre your diff, so the tyres don't rub (or at least rub less).
It's
#4 Posted : Wednesday, 17 September 2008 4:09:12 AM(UTC)
any other tips for lowering the car my self, im changing the rear shockers too, should i go gas or normal??
#5 Posted : Wednesday, 17 September 2008 6:42:51 AM(UTC)
Fitting lowered rear springs in a VL is easy. Simply jack up the car, support it on stands, and then support the diff. Undo the shock bolts, then lower the diff, and the original springs can be reefed out.
The lowered ones will fit in much easier than
#6 Posted : Thursday, 18 September 2008 3:24:19 AM(UTC)
thanks mate any other info tips etc etc, will i know if i have to use a pannah bar
#7 Posted : Thursday, 18 September 2008 4:31:17 AM(UTC)
OBVIOUSLY YOU ARE TAKING THE PISS MR gmhelp
PANHARD ROD - PANHARD ROD - PANHARD ROD - PANHARD ROD - PANHARD ROD - PANHARD ROD,
WTF IS A PANNAH BAR????????????
MATE, HAVE ANOTHER READ OF WHAT MICK SAID!!!!!!!!!!!!!!
Guest (5)
This page was generated in 0.082 seconds.
