edmundo Offline
#1 Posted : Thursday, 18 September 2008 4:51:26 AM(UTC)
edmundo
lads,
a few months ago i bought a ej sedan of an elderly chap. it is an original. He was the second owner, he has owned it for 30+ years. in the time he had it, it has been parked in his shed and stayed there. He told me that he hadnt started it for 25 years, it has 41000 miles on it and it was running perfectly when he put it in the shed. I got it home, put new fuel oil plugs points etc. got it started. Here is where im stuck. To get it running, I have to spray some aerostart down the carby. I can only run it for a few minutes as it cooks quickly. Compression is strong.
what do you guys think the prob. is with the motor cookin.
#2 Posted : Thursday, 18 September 2008 4:55:19 AM(UTC)
dicky thermostat? blocked radiator? stuffed water pump?
HQforme Offline
#3 Posted : Thursday, 18 September 2008 5:02:01 AM(UTC)
HQforme
Old motor might still be working hard to run, would get hot quickly. Maybe there's corrosion in the water galleries, blocked radiator, dud thermostat...and she's not flowing properly, or at all?
"Silly modern cars"
HQforme Offline
#4 Posted : Thursday, 18 September 2008 5:02:01 AM(UTC)
HQforme
Old motor might still be working hard to run, would get hot quickly. Maybe theres corrosion in the water galleries, blocked radiator, dud thermostat...and shes not flowing properly, or at all?
"Silly modern cars"
edmundo Offline
#5 Posted : Wednesday, 24 September 2008 10:40:43 PM(UTC)
edmundo
took off water pump, there is a bit of crusty crap on head outlet. water was a rusty color. is there anyway i can clean out or flush ports without removing the head. i will put a new water pump on.
#6 Posted : Monday, 29 September 2008 9:03:08 AM(UTC)
probably the radiator has dried out and the dirt in the tubes has gone hard and wont allow water to flow through. when storing radiators even for a few days do not let them dry out, plug the holes and fill with water, or at least lay them down flat and pu
