#1 Posted : Monday, 22 September 2008 3:16:44 AM(UTC)
Model: HX8WM80
Body No- 234708-A
Trim - 1898-18V
Paint - 567-15944
8M80 gl381866x
05/77
guv 1860 ahx 321011
utility seating 2
engl31transmk21hxaxlegv4
Can anyone advise if this is a sandman ute?
Should the chasis number match any of the plates?
Should the engine number match any of the plates?
#2 Posted : Monday, 22 September 2008 3:53:18 AM(UTC)
Yes, it's a HX XX7 ute.
#3 Posted : Monday, 22 September 2008 3:53:18 AM(UTC)
Yes, its a HX XX7 ute.
StuartH Offline
#4 Posted : Monday, 22 September 2008 4:05:52 AM(UTC)
StuartH
thanks for that. even though it hasn;t got that number on the id anywhere it is a sandman?
cheers Stuart
#5 Posted : Monday, 22 September 2008 4:11:59 AM(UTC)
#6 Posted : Monday, 22 September 2008 4:26:33 AM(UTC)
Not true. Giveaway is 18V trim on a base model. Buckets mean nothing except it's not a Sandman if it has a bench.
Edited by user Monday, 22 September 2008 4:29:07 AM(UTC)  | Reason: Not specified
#7 Posted : Monday, 22 September 2008 4:26:33 AM(UTC)
Not true. Giveaway is 18V trim on a base model. Buckets mean nothing except its not a Sandman if it has a bench.
HZute-efi-VS5L Offline
#8 Posted : Monday, 22 September 2008 4:31:59 AM(UTC)
HZute-efi-VS5L
you chassis number should be ahx 321011. the engine number is not on the id plates at all.
As byron said above. the seat cap can be 2 on any ute or pano. this does not mean its a sandman but is a good start. as he also said the trim 18V gives it aw
www.stickthisdecals.com.au
#9 Posted : Monday, 22 September 2008 4:50:58 AM(UTC)
Hi Guys.
A couple of comments.
8M80GLxxxxx - isnt that a 202 engine?
Shouldnt the chassis number have a letter at the end e.g. M - Melbourne or A - Adelaide etc.
Dr Terry.
Edited by user Monday, 22 September 2008 6:19:54 AM(UTC)  | Reason: Not specified
#10 Posted : Monday, 22 September 2008 4:50:58 AM(UTC)
Hi Guys.
8M80GLxxxxx - isn't that a 202 engine?
Shouldn't the chassis number have a letter at the end e.g. M - Melbourne or A - Adelaide etc.
Dr Terry.
#11 Posted : Monday, 22 September 2008 6:26:14 AM(UTC)
Terry
Hes left out the T. Should be 8M80TGL.
Chassis number is also wrong and should have an A on the end.
#12 Posted : Monday, 22 September 2008 5:51:48 PM(UTC)
My mistake, I thought he just swapped the G & the L.
This page was generated in 0.066 seconds.
