Fastlane
Holden Forums
Holden General Discussion
Holden Sandman Help Needed please....
Model: HX8WM80 Body No- 234708-A Trim - 1898-18V Paint - 567-15944 8M80 gl381866x 05/77 guv 1860 ahx 321011 utility seating 2 engl31transmk21hxaxlegv4
Can anyone advise if this is a sandman ute? Should the chasis number match any of the plates? Should the engine number match any of the plates?
Yes, it's a HX XX7 ute.
Yes, its a HX XX7 ute.
thanks for that. even though it hasn;t got that number on the id anywhere it is a sandman? cheers Stuart
Not true. Giveaway is 18V trim on a base model. Buckets mean nothing except it's not a Sandman if it has a bench. _______________________________________________________ If we all had the same (good) taste, who would buy all the Fords? Edited by user Monday, 22 September 2008 4:29:07 AM(UTC)
| Reason: Not specified |
Not true. Giveaway is 18V trim on a base model. Buckets mean nothing except its not a Sandman if it has a bench. _______________________________________________________ If we all had the same (good) taste, who would buy all the Fords? Edited by user Monday, 22 September 2008 4:29:07 AM(UTC)
you chassis number should be ahx 321011. the engine number is not on the id plates at all.
As byron said above. the seat cap can be 2 on any ute or pano. this does not mean its a sandman but is a good start. as he also said the trim 18V gives it aw |
Hi Guys. A couple of comments. 8M80GLxxxxx - isnt that a 202 engine? Shouldnt the chassis number have a letter at the end e.g. M - Melbourne or A - Adelaide etc. Dr Terry. Edited by user Monday, 22 September 2008 6:19:54 AM(UTC)
Hi Guys. A couple of comments. 8M80GLxxxxx - isn't that a 202 engine? Shouldn't the chassis number have a letter at the end e.g. M - Melbourne or A - Adelaide etc. Dr Terry. Edited by user Monday, 22 September 2008 6:19:54 AM(UTC)
Terry
Hes left out the T. Should be 8M80TGL.
Chassis number is also wrong and should have an A on the end.
My mistake, I thought he just swapped the G & the L.
Dr Terry |
Fastlane
Holden Forums
