HotRodder Offline
#1 Posted : Sunday, 28 September 2008 9:35:02 AM(UTC)
HotRodder
Does anyone know if its possible to widen a
VP Commodore differential or did any of the 93
or older Commodore diffs come wider than the VP ones, Id
love another 2 inches but it has to have the Commodore
stud pattern.
Edited by user Sunday, 2 November 2008 11:39:30 AM(UTC)  | Reason: Not specified
#2 Posted : Monday, 29 September 2008 9:17:37 AM(UTC)
VN-VS live axle is the widest common diff in the commodore range. The only live axles used after VT were in the crewman & 1 tonner models, and would be worth measuring, as they could be a little wider, but I dont know the answer.
As far as widening
#3 Posted : Monday, 29 September 2008 9:56:46 AM(UTC)
Cheaper to get an AU Falcon axle and re drill it to Commodore pattern as you will probably have to use re drilled AU axles in a widened Commodore housing anyway. Either that or new billet or Crewman axles (read expensive) will have to be purchased or poss
Edited by user Tuesday, 30 September 2008 1:17:06 AM(UTC)  | Reason: Not specified
HotRodder Offline
#4 Posted : Tuesday, 30 September 2008 10:06:58 PM(UTC)
HotRodder
Yes I posted the question again last night as when I clicked on the question to read the replies all that showed was a small picture of a Utility.
Edited by user Sunday, 2 November 2008 11:41:07 AM(UTC)  | Reason: Not specified
HotRodder Offline
#5 Posted : Tuesday, 30 September 2008 10:33:31 PM(UTC)
HotRodder
Hi Guys, Yes Commodorenut Im open to suggestions, Im interested in any diff as long as its what you call a live axle but it does require the Commodore stud pattern as the front setup Commodore to,I already have the mags and tyres so purchasing 2 new ones
#6 Posted : Wednesday, 1 October 2008 3:32:25 AM(UTC)
I think the AU is the best suggestion. AU was 1998-2002.
Are you looking at using leaf springs in the rear? If so, then a wagon diff would be the most suitable, as they still used the old cart springs...
Changing the stud pattern wouldnt be too hard
basketcasebear Offline
#7 Posted : Wednesday, 1 October 2008 6:19:23 AM(UTC)
basketcasebear
yes its me,,,basketcasebear!!! legendary au diff installer!! [incredibilis]
now, i put an au 3.35 diff out of a 1 tunner, in le transit,
and it was rather easy in the transit?? because of transit spring set up etc?
if you want to know exact measuremen
DOH!!!
#8 Posted : Wednesday, 1 October 2008 7:20:09 AM(UTC)
Bear you just beat me to it. I have just sent you an email on this very subject.
HotRodder yes Mick is right your best AU diff would come out of any AU BA or BF
wagon or ute as they all have leaf sprung rears. But if you are prepared to cut and weld
Edited by user Wednesday, 1 October 2008 7:28:57 AM(UTC)  | Reason: Not specified
#9 Posted : Wednesday, 1 October 2008 7:45:27 AM(UTC)
basketcasebear
hey hotrodder,
all i did with mine, was make a saddle out of 6mm c section, and bolt the springs onto this,
the transit has springs on top of axle, and the au had springs slung underneth axle.
the au axle has a good strong plate for fixing points, it w
DOH!!!
HotRodder Offline
#10 Posted : Wednesday, 1 October 2008 8:54:13 AM(UTC)
HotRodder
Hi Guys, Id go with either AU differential, sedan, utility or wagon as I have assess to a plasma cutter. I already have the saddles so hopefully theyll suit the AU differential and Id say for engineering purposes welding in the holes and drilling new ones
#11 Posted : Wednesday, 1 October 2008 8:57:12 AM(UTC)
Originally posted by basketcasebear
hey hotrodder,
i havent even welded new saddle to axle, probably not required, but
#12 Posted : Wednesday, 1 October 2008 10:27:38 AM(UTC)
basketcasebear
hey osrod,
those plates will probbly do it? i used 100mm channel, which fitted over axle like a stockin on a chooks lip!
you are probably right casper, should weld, but the way it ended up on the transit configuration, it is really strong, should take
DOH!!!
#13 Posted : Wednesday, 1 October 2008 7:14:29 PM(UTC)
Good news HotRodder the axle tubes are the same diameter on bot the Commodore and XA onwards Bog Warner/BTR diffs so your neatly made saddles will fit nicely on either.
I hope it was a joke about mounting the diff upside down as this would result i
#14 Posted : Thursday, 2 October 2008 6:00:12 AM(UTC)
basketcasebear
COVER PLATE TOO COVER PLATE>>>>>1460mm, [give or take]
from memory comm are about 1360???
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try
DOH!!!
#15 Posted : Monday, 10 November 2008 3:58:21 AM(UTC)
vr-s sedan live axle diffs made by btr engineering are 1 inch wider than the vn-p sedan diffs made by borg warner
Guest (10)
This page was generated in 0.148 seconds.
