HotRodder Offline
#1 Posted : Sunday, 28 September 2008 9:38:16 AM(UTC)
HotRodder
Does anyone know how much travel say a HQ tailshaft
had in a HQ Holden sedan using a 253 with a M21 box.
Have you hugged an English Bull Terrier today
#2 Posted : Sunday, 28 September 2008 9:57:24 AM(UTC)
Do you mean how far the yolk should enter the box?
The wear mark fom the seal should give you a clue.
HotRodder Offline
#3 Posted : Sunday, 28 September 2008 9:40:25 PM(UTC)
HotRodder
No sorry I mean how far will the tail shaft travel up and down with the suspension in a sedan.
I need to work out the tail shaft loop size for our rod and its using the same setup as a HQ Holden.
#4 Posted : Sunday, 28 September 2008 10:27:22 PM(UTC)
Jack the body up so the axle drops to its full travel then fit your loop with about 15mm clearance.
HotRodder Offline
#5 Posted : Monday, 29 September 2008 7:48:09 AM(UTC)
HotRodder
No dont have the body on the chassis yet just wondering if anyone knows the specifications for tail shaft travel.
#6 Posted : Monday, 29 September 2008 9:42:01 AM(UTC)
It will be governed by shocker travel anyway which Im guessing is not standard?
Also, the distance between the g/box and the diff will have an influence if not standard.
HotRodder Offline
#7 Posted : Tuesday, 30 September 2008 10:18:02 AM(UTC)
HotRodder
Alrighty then Im getting the front and rear leaf spring mounts and am going to mock up the rear end so to measure the travel, I have a couple of old tail shafts so will cut and re-weld the shaft to the length required and then get the correct measurements
#8 Posted : Tuesday, 30 September 2008 11:19:05 AM(UTC)
i thought it wouldnt move too far as the loop is only usually about a foot back from the gear box anyway and the gear box is a fixed point. if you put it too far back and you still run the risk of the front of the tail shaft hitting the ground if it falls
