#1 Posted : Tuesday, 30 September 2008 7:47:14 AM(UTC)
Any tips on filling in holes from WB stripes? I have removed the strips along the side of a WB statesman and the holes are quite large are there any tricks that anyone knows to filling these in...ie im probably going to just bog them up.any help or advice?
Jim in adelaide
#2 Posted : Tuesday, 30 September 2008 8:22:39 AM(UTC)
best tip.... put the strips back on, easier believe me
AFTER 1972 THERE AINT NO MUSCLE CARS AND MATCHING NUMBERS ARE FOR TIMES TABLES....
XY GTHO PH111 , now thats muscle...
#3 Posted : Tuesday, 30 September 2008 9:18:39 AM(UTC)
using a countersink drill bit, clean out the edge of the hole to make a nice clean surface with some good exposed metal.
Grab a lump of copper (bit of bar) and press it up against the hole from the inside.
Buzz a MIG weld into the hole - starting at the
HotRodder Offline
#4 Posted : Tuesday, 30 September 2008 9:50:52 AM(UTC)
HotRodder
Lead Filler
Have you hugged an English Bull Terrier today
#5 Posted : Tuesday, 30 September 2008 11:26:11 AM(UTC)
my old Tafe teacher used to use silver solder to clean up door gaps and fill in old rubber strip holes. it ended up being stronger than the car body and lasted years.
#6 Posted : Tuesday, 30 September 2008 4:22:56 PM(UTC)
Thanxz seems like a big job kinda,might get smaller strips!!
Natmeisterus Offline
#7 Posted : Tuesday, 30 September 2008 10:01:51 PM(UTC)
Natmeisterus
leave the strip on...
if you ever park your stato in a car park, all it takes is one fat guy to park next to you and bam, dinted door. Unless its an all out show car, the strips are there for a reason, and believe me youll be glad you kept them when your
#8 Posted : Wednesday, 1 October 2008 1:49:50 AM(UTC)
Thanxz all for your help,as mention ive already taken them off,there was problems underneath with rust patches starting to appear etc. to be honest
ive never liked them anyway.There is a new product out ,could be old, called METAL FINISH im using that f
chandler Offline
#9 Posted : Thursday, 2 October 2008 6:25:29 AM(UTC)
chandler
metal finish is **** to use trust me its a bastard to use better off just using bog if u dont want a big job
never fear the CHAN is here
"CHAN"
#10 Posted : Thursday, 2 October 2008 9:59:56 PM(UTC)
Chandler ,your right! its hard to work with but on opening and closings such as doors properly applied this sets like steel,highly recommend it but as you said ,bastard to work with!
Jim in adelaide
#11 Posted : Thursday, 2 October 2008 10:17:44 PM(UTC)
Use pop rivets it quick and easy and its an excellent finish.
Guest (12)
