HJHeaven Offline
#1 Posted : Thursday, 9 October 2008 10:47:41 AM(UTC)
HJHeaven
Hi All
I am going to install a rochester quadrajet on a mild 308 in a HJ (because the holley 650 DP i have seems to be very thirsty).
Does anyone have an installation guide that can show me how to install the new carby?
All help appreciated.
Mark
I am not allowed a mistress so i got a GTS - and its better
A GTS/4 is a monaro - so nuuur
#2 Posted : Thursday, 9 October 2008 4:07:22 PM(UTC)
Does it still have the original HG inlet manifold? If so, best bet is to find an original HT-HJ or LH - mid 1976 LX 308 and take some pictures with the air cleaner off. Failing that the Gregorys manual isnt bad in this area - number 86.
_______________
#3 Posted : Thursday, 9 October 2008 7:40:31 PM(UTC)
Hi ,I think the roch flows at about 675cfm in full flight,but has small front barrels(better econ)they are from what ive heard a better carby when tune/built right.im running both on my cars,403ci olds with a holley small front and very large rear barrels
Edited by user Thursday, 9 October 2008 7:42:11 PM(UTC)  | Reason: Not specified
74HJLS Offline
#4 Posted : Saturday, 11 October 2008 3:33:30 AM(UTC)
74HJLS
Jim, I think you will find the Rochester Quadrajet is rated to flow between 760 to 780 depending on model. The good thing about them is they have variable flow and only supply the airflow required. But as you say small primaries, good economy and big seco
Pete.
HJHeaven Offline
#5 Posted : Sunday, 12 October 2008 12:31:43 AM(UTC)
HJHeaven
Currently waiting for my Rochester to be delivered but am having a look at the Holley 650 DP which i currently have on a mild 308 to try get it running right.
I have taken off the bowls and cleaned them out and they are full of fuel but i am having the
mrhqute Offline
#6 Posted : Sunday, 12 October 2008 7:44:01 AM(UTC)
mrhqute
Is your holley box stock, or has it been jetted for the 308?
I think most 650 DPs are jetted from the factory for around 350/351 + ci.
If it hasnt yet been jetted, get a jet kit and start jetting down the primaries.
Ross
