#1 Posted : Saturday, 11 October 2008 6:21:33 PM(UTC)
I looking for a speed sensor for a Turbo 350. Does anyone know if the standard speed sensor out of a Commodore VN Turbo 700 will fit the Turbo 350?
Thanks in advance.
Andrew
#2 Posted : Saturday, 11 October 2008 6:34:52 PM(UTC)
Yes it will, but you will need to also fit a speedo cable? If you do Kalmaker make an inline sensor that screw into the box and the cable screws into the other end. Plus the Kalmaker speed sensor is a 2 pulse per rev sensor so you dont need a pulse conver
#3 Posted : Saturday, 11 October 2008 6:34:52 PM(UTC)
Yes it will, but you will need to also fit a speedo cable? If you do Kalmaker make an inline sensor that screw into the box and the cable screws into the other end. Plus the Kalmaker speed sensor is a 2 pulse per rev sensor so you don't need a pulse conve
mmazz30 Offline
#4 Posted : Sunday, 12 October 2008 2:02:17 AM(UTC)
mmazz30
Hey Byron are you saying that VR ECU/memcal requires 10 pulse and not 2 pulse like VN/P?
Im running VR manual ecu and memcal in my monaro and im running a "T" drive at the tranny.
From the tranny (t700) i have a short cable to the centre of the "t"drive
#5 Posted : Sunday, 12 October 2008 2:43:07 AM(UTC)
Yes, VR onwards uses 10 pulse for the speedo and ECU. I cant remember what pulse rate the cruise module uses in a VR on, but VN-VP use 2 pulse. If youve modifed ppk however it doesnt matter which speed sensor you use as adjusting that constant will correc
mmazz30 Offline
#6 Posted : Sunday, 12 October 2008 7:24:35 AM(UTC)
mmazz30
Ahhh ok almost had myself worried for a second as everything works fine as it is.
Yeah im not sure either on the later VR/VS and the VT module pulse rate.
I have them all and stayed with the VN module and used the VS ecotec cable (shorter)for my homemad
