#1 Posted : Sunday, 12 October 2008 2:11:08 AM(UTC)
howdy i have an ef fairmont thats running a bit rough was going to put some injector cleaner through it but have heard whispers that some injector cleaners do more harm than good.. is this true and any recomendations on brand nulon, flash lube? thanks george
Paul351xb Offline
#2 Posted : Sunday, 12 October 2008 4:33:20 AM(UTC)
Paul351xb
Nulons fine. Wynnes Spitfires good too. If it's from Wynnes or Nulon you can usually rely on it to be a good product. I've been using spitfire in the wifes car for years. Never an issue.
#3 Posted : Sunday, 12 October 2008 6:22:57 AM(UTC)
At the age of the car and probably the km,s, It probably would not hurt to pull the injectors out and have them serviced?
#4 Posted : Sunday, 12 October 2008 9:06:11 AM(UTC)
yeah age and ks considered i dont want to spend a great deal of $ on the car so will run with injector cleaner first and if all goes well i wont need to get the injectors serviced.
thanks for the quick reply.
george
Paul351xb Offline
#5 Posted : Sunday, 12 October 2008 9:34:37 AM(UTC)
Paul351xb
Run the injector cleaner with a full tank or premium unleaded. Shell is the best I'm told. It helps
sly376 Offline
#6 Posted : Sunday, 12 October 2008 10:02:06 PM(UTC)
sly376
hmmm take a look at your ignition H/T leads, if they look like they have a white powdery look, change them, it's very common. Would not hurt to remove those injectors and have them cleaned properly though.
#7 Posted : Monday, 13 October 2008 12:25:03 AM(UTC)
yeah it is probably the best option but the car is still working so if the injector cleaner doesnt do the job thats the next step. will look at the ignition leads soon. cheers
christoss Offline
#8 Posted : Monday, 13 October 2008 8:45:52 AM(UTC)
christoss
also check intake manifold gasket or other vac leaks
Smithys Skilled Autogas 0397622333
This page was generated in 0.108 seconds.
