#1 Posted : Monday, 13 October 2008 6:23:14 AM(UTC)
2800 turbo diesel 4x4 diesel major nocking in engine blows lots of smoke when i first start it up anusual for a diesel motor to brake down like this i thought only 200000 kms any ideas fellow holden fans ??
playwme Offline
#2 Posted : Monday, 13 October 2008 6:34:34 AM(UTC)
playwme
Lack of oil will cause damage like that.
#3 Posted : Monday, 13 October 2008 6:38:23 AM(UTC)
Old oil will too if you are lucky an oil change will fix it...
If at first you dont succeed then skydiving is not for you.
Edited by user Monday, 13 October 2008 6:39:06 AM(UTC)  | Reason: Not specified
#4 Posted : Monday, 13 October 2008 6:38:43 AM(UTC)
still got a full sump of oil
#5 Posted : Monday, 13 October 2008 6:41:47 AM(UTC)
hopefully old oil i thought oil pump nacked maybee might before i makehat try changing t any harsh decisions
#6 Posted : Monday, 13 October 2008 6:43:24 AM(UTC)
bugga that last message makes no sense lol
trubluhq Offline
#7 Posted : Monday, 13 October 2008 7:51:30 PM(UTC)
trubluhq
I have owned two 2.8TDs. 2 major motor diffs as I saw it. Early 90s models had a huge turbo, and later 90s had a tiny one. Change oil often and use GOOD diesel grade oil. Not 20W/50. Mine went past 250Km no engine issues at all.
Engine will need lifter
#8 Posted : Tuesday, 14 October 2008 3:58:48 AM(UTC)
cheers mate
Oily Offline
#9 Posted : Tuesday, 14 October 2008 6:30:47 PM(UTC)
Oily
Dan, Diesels as you know it are notoriously noisey, especially cold.
But if you are going to dismantle it make sure some diagnosis is done first and preferably have some one familiar with that model listen to it(cylinder noise can normally be isolated by
basketcasebear Offline
#10 Posted : Thursday, 16 October 2008 7:09:08 AM(UTC)
basketcasebear
i had a diesal in my transit, 308 now, thank the lord,, but it was blowing smoke like crazy when i could get it to run!!
but a good mechanic told me to use fuchs oil,,and it made a huge difference,, no smoke at all after,
hope his helps,
bcb
DOH!!!
#11 Posted : Sunday, 19 October 2008 6:54:02 AM(UTC)
cheers all
This page was generated in 0.082 seconds.
