gday blokes, ive got a trimatic 3speed that i want to put onto a black 202 which then will be going into a hr pano. my questions are what do i need to fit the box under the car? what brackets, cables and anything else will i need to fit as the car is a rolling shell so i have nothing to go by. also too, what engine mounts can i use to fit the black 202 into the pano? all help will be appreciated mick
The black 202 is the same block as a red 202 so itll fit into the HR existing engine mount points just fine. The trimatic will bolt up to the black 202 just fine too. The gearbox crossmember will need to be modified, the speedo cable will need to be cha |
202 and three on the tree, can't get more Aussie than that!! |
cheers mate for the info, as far as i know the trimatic is the later style as its got the extra webbing. well thats how ive been told to tell them apart. do you know how much work it is modifying the crossmember? little bit of cutting and welding is no d
The 202 will fit straight into an HR, the mounting position is the same. Use HR rubber mounts. For the rear mounts use HR Powerglide stuff, likewise use an HR Powerglide tailshaft. You will have to fit the early (short) water pump, otherwise it will hit t |
thanx dr terry i picked up the box about two months ago and i am lucky enough it already has the linkage for a b&m well so ive been told by the company who rebuilt it all. while your online dr terry is there any modern dash instruments that fit into the
The good news is that all red/blue/black 6 cylinder engine mounts are the same so the Commodore ones will work as well as HR items.
The bad news is that you will need an HR sump plus a tailshaft and a gearbox cross member from an automatic HR.
Ahh Peter and Dr Terry there were no replies when I started typing. Ill have to type quicker.
If at first you dont succeed then skydiving is not for Edited by user Thursday, 16 October 2008 9:59:41 PM(UTC)
| Reason: Not specified |
lol cheers anyway jim ive got a spare hr sedan here i wanna use as much as possible so which is the way to go? peters, dr terrys or jims? or can i choose either of the three options? cheers again fellas mick
Be also aware that most later trimatics were left hand shift so may not connect standard HR shifters, but if youre using a B&M that wont matter.
_______________________________________________________ If we all had the same (good) taste, who would buy |
cheers hk im trying to picture the box and im sure it is on the left but yeah im glad it wouldnt become a hassle with the b&m. mick
quote: Originally posted by Jim5.0
The good news is that all red/blue/black 6 cylinder engine mounts are the same so the Commo |
quote: Originally posted by peterwmh
The gearbox crossmember will need to be modified, the speedo cable will need to be change |
