Time to rebuild the 308.Can anyone recommend a good engine rebuilder in NSW. Just want to L34 the heads ,small cam,balance the bottom end. Red 308, building the car like I had in the early 80s.Factory style paint and stripes David Jones interior,lowered,cam,heads,holly and the biggest hotwires that scraped all four corners.I won,t put side pipes on this time. Ah memories and defect stickers.
West End Performance down Campbelltown way have done some good jobs for a number of people I know. We also got them to do the machine work on the last motor I built, and it was spot-on.
Mick ________________________________________________ |
Best thing for a 308 is stroke it. Costs bugger all more in a rebuild and makes heaps more hp/torque than any other mods. Only problems then are gearbox and diff!
_______________________________________________________ If we all had the same (good) ta |
I get all confused with this 355,383 thing.I,m happy with a lumpy idle and the chirp of tires in second.My nephew runs 14.5s so I just need to go quicker than that. HT 308 aussie 4speed 3,08 LSD .What does the 308 need? And don,t say a chev,if I could aff
You dont want to go stroking it with that box and diff!
hey hk1837. How would a sbc with a 383 stoker, infront of a turbo 700 built to take 800 hp and a diff r atio of 3.36 go?
Good if tuned right with the right cam (to suit usage and diff) and correct torque converter for the application.
The cam is mild to suit the standard torque converter on turbo 700. The engine has been to built to make 400. Would that suit the diff?
Sounds OK to me. With the Overdrive you might even want to investigate 3.55 gearing.
