ringfeder3 Offline
#1 Posted : Thursday, 30 October 2008 3:27:02 AM(UTC)
ringfeder3
Having just completely refurbished two Girlock alloy brake calipers with pads, seals and paint, I find that they dont seem to fit onto the HJ stub axles I intended to mount them to. I suppose I should have checked first, but I thought they't all be the same throughout the 'H' series. Can I machine the caliper? It would appear that the edge of the caliper is fouling the upright on the stub axle slightly. Help.
ringfeder3 Offline
#2 Posted : Thursday, 30 October 2008 3:31:34 AM(UTC)
ringfeder3
To clarify, the calipers are steel/alloy, stamped 1976...
CherryBomb Johnston Offline
#3 Posted : Thursday, 30 October 2008 5:28:08 AM(UTC)
CherryBomb Johnston
I thought the same!.. Do the stubs from the V8 model differ from the 6 models?
A mate of mine owned a stock LH once, also fitted with Girlocks (alloy), Could there be a mix up?
Because stock sucks
"Because stock sucks"
#4 Posted : Thursday, 30 October 2008 5:45:52 AM(UTC)
my old HZ ute had PBR that was the same as a Torana i seen.
#5 Posted : Thursday, 30 October 2008 6:16:19 PM(UTC)
my hj statesman has girlock it may pay to contact a dealer to see if any changes were made to the calipers after 75 also might sound silly but do u have them on the correct side.
#6 Posted : Thursday, 30 October 2008 11:33:04 PM(UTC)
I did the same change on my hj tonner, not a problem bolted straight on!
